Home Forums Blogs Cobra Marques Info Groups Classifieds Gallery Arcade Shopping
Old 07-05-08, 09:58 AM
Grahamw Grahamw is offline
Rover v8 Exhaust manifolds
One of the exhaust manifolds on my Rover v8 Mk3 sumo has broken. I am considering welding it, but also considering what options are availiable to replace them.
Anybody recommend a supplier for a set of new exhaust manifolds (Rover v8 with side pipes)?
Thanks in anticipation,
Graham
Old 07-05-08, 12:27 PM
427scr's Avatar
427scr 427scr is offline
Graham
Anybody except shiney bits....ruined my brother in laws car.
Old 07-05-08, 02:56 PM
stu e's Avatar
stu e stu e is offline
Graham
Hi Graham
I'd send a PM to Chimera (Anthony), he was selling sidepipes and fitting them to Sumo's. He's based in Taunton and builds Sumo's for a living.
Cheers Stu.
Old 07-05-08, 03:42 PM
Smile Exhaust Manifolds
Thanks Stu,
will give him a try.
Old 08-05-08, 07:52 PM
tonym's Avatar
tonym tonym is offline
Club Chairman
Originally Posted by stu e View Post
Hi Graham
Cheers Stu.
I've seen Antony's sidepipes and very nice they are too. Also try Gwaks place, sidepipes as they're of good quality as well.
BIG TONE
Rover 4.8, Megasquirt and EDIS 8 in a MK3 Sumo
Old 08-05-08, 08:39 PM
bluetoon's Avatar
bluetoon bluetoon is online now
Hey Graham
Before you go and spend ££££ on new manifolds, have you considered why they broke.
The standard engine mounts are considered to be too soft and allow alot of engine rock. These may need to be replaced with stiffer ones. Also, how are the exhausts mounted, this again may contribute to failures of the welds on the manifold.
Hope this helps.
Jim
How are the doors and bonnet supposed to fit again ? .
Old 09-05-08, 09:33 AM
Smile
Originally Posted by bluetoon View Post
Hey Graham
Hope this helps.
Jim
Jim,
You are absolutly right, am looking to replace the engine mounts at the same time. I also intend to add additional support to the side pipes and also considering additional support to prevent the motor twisting under heavy acceleration.
I am convinced having seen the inside of both the Pilgrim Manifold and the side pipes that this system is very restrictive, so am eventually going to replace the manifold and the baffels in the side pipes. (I always thought that the car should have gone better than it does, so this probably explains quite a bit.
Graham
Old 09-05-08, 10:35 AM
chedz's Avatar
chedz chedz is offline
Just a thought but you might want less support. The pipes will always want to move a little and so should be able to. They can be mounted on rubber bobbins to allow them to flex rather than snap, also some people only support them at the back.
I have a section of flexible exhaust pipe between the headers and the side pipes, side pipes mounted on rubber bobbins and stiff engine mounts (land rover ones). No problems so far.
cheers
G
Old 09-05-08, 11:23 AM
chesterak chesterak is online now
If you are familiar with the Dax set up....single rubber mounting at the rear of the sidepipe, I have the same set up my AK and, so far, no problems. You can mount exhaust system too rigidly.....
Stan
Old 09-05-08, 01:47 PM
Thumbs up Thanks
Thanks guys for all the valuable comments, much appreciated. All I need to do now is get some headers made!
Graham
Tags
exhaust, manifold, rover
Rover v8 Exhaust manifolds wanted Grahamw Wanted Adverts 0 07-05-08 09:51 AM
Wanted MGB V8 Exhaust manifolds for Rover V8 Dixie Engine Tech Tips & Questions 0 04-05-07 10:45 PM
Sumo Rover V8 exhaust manifolds westy Pilgrim Sumo Technical Questions 5 16-03-07 11:35 AM
Pilgrim V8 Rover exhaust manifolds westy Pilgrim Sumo Technical Questions 21 04-10-05 08:44 PM
Exhaust manifolds V8 Rover markieboy General Cobra Discussion 12 06-06-03 05:06 PM
