Gauge sender locations?
I have a Chevy 350 with Edelbrock Performer RPM intake. Can someone please fill me in on the gauge sender locations? I can see the senders, but have no idea which senders control which gauges. I could short the contacts and get an assistant to check which gauge flickers, but it'd be a tad easier if someone could itemise them for me! I'm concerned, specifically, about the voltmeter, coolant temp, engine oil pressure and engine oil temp.
Cheers, Ian.
2003 DAX Tojeiro De Dion |
Ian, I can't help but I'm about to be in the same position. I have a couple of Chevy books but they don't give that sort of detail.
I would also be interested in where the senders are on the engine. Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ Building a Dax Tojeiro, Chevy 350, Tremec TK05, 3.54 Powerloc diff. Should be done in a couple of weeks! |
Location of water temp sender between 1 and 3 plugs probably explains why my temp gauge isn't working... the sender is very, very close to the header pipes! Will have to remediate and wrap with heat-reflecting tape. Cheers, Ian.
| Fuel tank sender/fuel gauge | Dek | General Cobra Discussion | 3 | 16-05-07 09:34 AM |
| Fuel gauge sender gremlin. | DavidSaw | DAX Technical Questions | 4 | 03-01-05 12:34 PM |
| Water temp. gauge/sender question | ian | General Tech Tips & Questions | 6 | 31-07-03 09:21 PM |
| Fuel gauge sender fitting | beanpole | Pilgrim Sumo Technical Questions | 3 | 05-07-03 01:02 PM |
| Fuel Gauge Sender Unit | VinceGledhill | AK Technical Questions | 1 | 12-03-03 12:41 PM |
