Sorry to sound like a broken record Warren, But it's really not a good idea to have a fuel filter on top of the engine that is made of plastic or glass.
The temperature on top of the motor will be enough to soften the plastic and it could split spraying fuel on the hot exhaust headers. Keep the filter near the back of the car before the filter or use one of the Filter King type filters in the engine bay. These are designed to withstand temperatures under the bonnet. Cheers Craig.
Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 14
Mike |
I have already got one inline filter toward the back of the car but saw a thread somewhere suggesting one on the tank outlet and another between fuel pump and carb. My pump is mechanical so at the moment that spot there is the coolest spot. I knew about the problems with the glass ones are the plastic ones susceptible as well? Filter king type? Any specific type? Cheers Warren |
I'm thinking that it's possible that more crap has got into the carb effecting idle mixture. So the plan it to check the plugs, clean the carb again checking the idle mixture screws in particular and go from there. Cheers Warren |
I have never seen the need for 2 filters myself. Filtering the fuel before it gets to the pump is good practice as it protects the pump valves and diaphragms from dirt.
The only stuff that is going to come out the pump is fuel as clean as it was when you put it into the pump. If the pump starts breaking up and shedding debris into the fuel then you are likely to stop fairly soon anyway. I would go back to one filter before the pump. Craig.
Holley Carb Problem
Had the same problem last Monday. Took float chamber off and found black plastic float was discoloured, been reliably informed that it probably has a hole in it and may not be rising when chamber is full on slowing revs.
Regards Alex |
Erm, I think I fixed it, notice the immediate claim of triumph over adversity
For those following this I took out the plugs and they were mucky, carbony but bearing in mind this problem starting with s stuck float and petrol pooring down the throat of the carb this will have run very rich the ten miles home. So I cleaned em up and put them back in. I checked both float levels and the one at the rear was still a little high so I readjusted that. The carb looked clean throughout so I started it and ran it up to temp, sounded a bit rough and then I noticed a plug lead not replaced after checking plugs. That's better. Now I checked the idle screws, nearside seemed to have no effect what so ever, offside I was expecting to lean off but it stopped after about half a turn, weird, as I turned it back I suddenly got improved tickover, really nice. Tried the nearside and maybe a slight change but barely discernable. Not wishing to move these screws too far I adjusted the idle down and it sounds sweet. Daren't take it out yet as Craig has put the wind up me with the plastic fuel filter and I haven't any spare petrol pipe 'til tomorrow when I will take it for a spin. Even sticking it back in the garage er in doors say, 'that's sounds better'. One comment I would be interested in hearing feedback on. These idle mixture needles don't have any springs behind them and turn with the lightest of pressure, anyone else found this? Cheers & thanks to those helping out with suggestions. Warren |
David SR Cobra, 350 Chevy, 120db sidepipes with flames on overrun!! |
| Holley Carb | Wilburn | General Cobra Discussion | 3 | 03-05-08 07:57 PM |
| Holley Carb | bazbo | Parts for sale | 5 | 07-09-07 08:22 PM |
| Holley Carb Questions | cliffords | General Tech Tips & Questions | 3 | 04-11-06 03:18 PM |
| holley carb | Clarkson | General Tech Tips & Questions | 10 | 29-04-03 10:18 PM |
| Holley 390 CFM Carb | sumov8 | General Tech Tips & Questions | 8 | 09-01-03 06:45 PM |
