| SBC rocker upgrade advice needed I want to upgrade my stamped steel rockers to roller rockers. Question is, do I need self-aligning rockers, or not? My understanding is that SA rockers are generally required if the head does not have guideplates (which my heads don't have). However, I've read conflicting statements regarding whether SA rockers are needed, or not. So, I've attached a pic of one of my heads below, with the pushrod and rocker removed from #8. Comments? ![]() Cheers, Ian.
__________________ 2003 DAX Tojeiro De Dion |
| Quote:
those are self aligning rockers but someone has converted the heads to screw in studs so in theory you could use guide plates with that setup and regular rockers. However the pushrod holes look a bit on the small side so you might end up with an alignment problem unless you enlarged them, thats a head off job though. Oh, and seeing your looking for comments thats #2 not #8 Regards Mike |
| Quote:
So, I need self-aligning rockers with my current set-up, or ditch the current heads, buy some Patriots from you and get some normal roller rockers Cheers, Ian.
| Ian, no, you could use normal rockers if you fit guide plates and some of the work(screw in studs) has allready been done. Mike |
| Quote:
Cheers, Ian.
| Quote:
Cheers, Ian.
| advice needed please | vinster | General Cobra Discussion | 7 | 26-11-07 09:33 AM |
| hi everyone and advice needed ! | dolphinboy400 | Newbies | 14 | 18-11-07 06:04 PM |
| Advice needed-help! | dingocooke | General Cobra Discussion | 3 | 30-11-06 03:05 PM |
| Rover V8 Upgrade Advice | jabooth | Engine Tech Tips & Questions | 31 | 30-07-06 06:19 PM |
| Advice needed | breskit | General Tech Tips & Questions | 7 | 16-09-03 01:22 PM |
