I'd certainly try to find out what's up before running the engine again. People do say that they are a low pressure engine but both my fairly worn out 3.5 and new 4.6 both show over 30 psi at tickover. (Same pump on both engines) I think that my pump has a high pressure spring fitted. Pete
I refuse to engage in a battle of wits with an unarmed opponent. |
Dave,
Are you running a mechanical or electric pressure gauge? Is the engine making loud clacking noises?
Tony "I couldn't repair your brakes, so I made your horn louder." A Black Unique Motorcars 427S/C 427FE 482 stroker close ratio toploader 3.31 Jag IRS |
If the engine has inadequate oil pressure is is usually noisy. Is the pressure sending unit in an easy place to get to? I would remove the pressure sending unit and hook the mechanical gauge up there.
