Old 19-05-08, 07:22 AM
Dizzy connections
Back from beaulieu with a new DLM8 Dizzy and coil.
Now, the ignition module has two spade connectors on it but with no marking.
They are in a shape like this | --
Which wire goes where to the Coil please ??
Old 19-05-08, 08:57 AM
Sidecarbod's Avatar
If nobody supplies you with an answer I'll check out my dizzy when I get home.
Pete
Old 19-05-08, 04:49 PM
Sidecarbod's Avatar
Here we go:-
If you look at the connectors as a T then the "l" bit goes to the 12v of the coil, the coil also needs to be fed 12v at the same coil terminal. The
"--" part of the T goes to the neg of the coil. On my car another lead also comes off this terminal and goes to the rev counter. You do need an electronic 12v coil otherwise you will have problems!
HTH,
Pete
Old 20-05-08, 06:47 AM
Thanks for that Sidecarbod
Dizzy Dutch Paul The Cockpit 11 23-11-06 11:06 PM
sd1 dizzy craigh Engine Tech Tips & Questions 10 10-09-04 07:44 AM
Connections! Phil McCann Engine Tech Tips & Questions 1 16-05-04 04:55 PM
dizzy rv8 MARTIN123 General Tech Tips & Questions 2 15-07-03 09:17 AM
Connections Kelvin General Tech Tips & Questions 22 27-11-02 12:13 AM
