| Quote:
I'm going to give all the vacuum pipes a thorough check tomorrow morning, and also try the WD40/soapy water trick. I'm just amazed that a noise so deafeningly loud can come from a leak that's so hard to pinpoint! Thanks again for all your input guys - I'll keep you posted on progress. Cheers |
| Quote:
| Tip to help track down the exact point where the noise is coming from: Take a metre or so of 1/4" dia plastic pipe or similar. Put one end in your ear, move the other end around the engine bay close to and all over the engine. Will intensify the location of the noise - you will have to be pretty much directly over it before the noise will travel up the pipe (might be worth an ear plug in the other ear as well).
| Quote:
Great idea - I'll give that a whirl tomorrow. |
| could try disconnecting the various pipes before taking the manifold off, see if that changes anything. luck
| Quote:
Vac advance and vac gauge pipes already checked. Will check the PCV and brake servo pipes tomorrow morning. I'm also going take the carb right off and inspect it thoroughly for any cracks/leaks. |
| A mate of mine had the crankcase breather block up enough to draw air into the crankcase via a poorly fitted rear intake manifold gasket. This made a similar noise. Just another thought. Good luck.
__________________ Ian DAX 454 Chevy The closer I get to getting it running, the further away I actually am!! |
| Quote:
Following Wilf's earlier suggestion, I've modified my mechanic's stethoscope tonight. A large tube going into two smaller tubes connected to each earpiece. My missus thinks I'm completely mad now she's seen me wandering around wearing this contraption! What with all the time I've spent over the past six weeks or so either under the car or with my head under the bonnet, I fear she's going to be calling for the men in white coats soon ..... ![]() |
| Quote:
| Surround Sound | Miket | Feedback, Membership and Help | 36 | 11-01-08 09:08 PM |
| Why does my car sound like a Harley??? | bc_suv | Engine Tech Tips & Questions | 12 | 22-10-07 09:17 PM |
| Sound deadening | Tidyshed | Pilgrim Sumo Technical Questions | 14 | 27-08-07 07:26 PM |
| What a sound ! | simon | General Cobra Discussion | 2 | 10-11-06 03:37 PM |
| Wired for sound | hfbradley01 | General Cobra Discussion | 28 | 16-02-04 03:07 PM |
