  #41 (permalink)
Old 06-06-08, 07:38 AM
V8burble's Avatar
Has the vacuum advance on the distributor been ruled out as a cause (split diaphragm) BTW?
  #42 (permalink)
Old 06-06-08, 05:48 PM
conrod's Avatar
A quick update! I woke up this morning feeling lousy - I had a headache yesterday which I put down to the noise () and to quite a high dose of petrol and exhaust fumes!
I had other things to do today anyway - that I should have been doing instead of working on the Cob, as 'er indoors reminded me
So I've put it all on hold today. I'll start again tomorrow, and I'm going to go right back to the beginning with the leak location and repeat all the tests. I must have missed something - hopefully returning to this after a break and with a clear head will yield a positive result ......
Thanks for all your input and moral support!
Alan
Thames Valley Area Rep
My Gallery - click here
My Albums - click here
  #43 (permalink)
Old 06-06-08, 06:02 PM
Wilburn's Avatar
Hi Alan,
Just listened to your video and it does sound just like my carb when it was sucking air through the spindle on the secondaries!
Paul
Paul
DB Replica build 98 - Dax De Dion
David Clarkson - 383 stroker
Barry Grant speed demon carb
Roller Cam
Edelbrock performer air gap inlet manifold
Visit my Cobra photo gallery at paulwilburn.co.uk
  #44 (permalink)
Old 06-06-08, 06:12 PM
conrod's Avatar
Originally Posted by Wilburn View Post
Hi Alan,
Paul
Yes - the secondary spindle is ridiculously loose on my 4150 - been like that since I fitted it, mind. But if it is the cause, or a contributor, then the package you've sent will solve it. Thanks again Paul - you're a star!
But for now it's time to light the barbie and pull a cold lager from the fridge!
Cheers.
Alan
  #45 (permalink)
Old 06-06-08, 06:13 PM
Wilburn's Avatar
Good idea, think I'll do the same
Let me know tomorrow how you get on ............
Paul
Paul
Roller Cam
  #46 (permalink)
Old 07-06-08, 01:49 PM
conrod's Avatar
Gotcha!!!
What a difference a good night's sleep and a refreshed, logical mind makes!
I found the leak at last - in the inlet manifold between 6 & 8. And I was really lucky with the manifold removal. I used a modelling knife with a 1" long blade (1/4" going down to a point at the end) and cut through the RTV front and rear. Then I inserted an old blunt 1" chisel at the site of the leak and it just popped up - happy days!!!
So now for the clean-up and the reassembly. And now I have the coolant drained I can replace the leaking core plug - every cloud has a silver lining ......
Alan
  #47 (permalink)
Old 07-06-08, 01:52 PM
Vidge's Avatar
Well done Use No Nails to refit it, that'll learn it to leak on you. /Joke
Tojeiro De Dion
The man from Dax say "It's within tolerance, you need a bigger hammer."
  #48 (permalink)
Old 07-06-08, 02:10 PM
Hurrah!
Better put a good straight edge on the inlet manifold to see if it has warped to cause your gasket breakage.
  #49 (permalink)
Old 07-06-08, 04:25 PM
conrod's Avatar
Originally Posted by wilf View Post
Hurrah!
Wilf,
Have checked. Totally flat on the LH side, and also flat on the RH side except for the last 3" (across the rear water port) where I can squeeze a 3 thou gauge at the end. That's the side that was leaking, but as the warp is beyond nos 6&8 inlets (where teh leak was), I'd say it's probably OK. What say you?
Alan
  #50 (permalink)
Old 07-06-08, 04:31 PM
conrod's Avatar
Next question! I blocked the ports in the head, and laid clean cloths in the valley before I started removing the old silicone sealant and gaskets. I'm pretty sure nothing has dropped into the valley. It's the silicone I'm concerned about - stray pieces are very good at blocking oilways, and I've seen the damage that can cause!
I'm therefore going to change the oil and filter - it was due for a change anyway. The question is, should I drain it cold (before I fire up the engine), or should I let the engine warm up then drain the oil. I'm thinking of the latter at present.
Alan
Surround Sound Miket Feedback, Membership and Help 36 11-01-08 10:08 PM
Why does my car sound like a Harley??? bc_suv Engine Tech Tips & Questions 12 22-10-07 10:17 PM
Sound deadening Tidyshed Pilgrim Sumo Technical Questions 14 27-08-07 08:26 PM
What a sound ! simon General Cobra Discussion 2 10-11-06 04:37 PM
Wired for sound hfbradley01 General Cobra Discussion 28 16-02-04 04:07 PM
