| Quote:
__________________ David Clifford AK427, Tremec and Stroker. |
| When I was trying to get oil pressure on my engine before start up I decided I had dropped a small screw down the dizzy hole. I got a bit of brake vacuum hose and made to hose on the vacuum cleaner a smaller bore and therefore higher pressure in order to take out the small screw from the oily hole. I did this for ages and then gave up as I could not determine if I had got it or not. I then found the small screw on the end of the screwdriver I had been using held by the magnetism they get after a while. Still think my super power small bore vacuum cleaner was a great invention.
| Quote:
That's spooky! You've reminded me of another motorbike story! Then I realised that I had removed the spark plugs before removing the rocker cover - and immediately concluded that the damn dowels must have dropped down the plug holes as I removed the cover. I invented the very same device as your good self - a series of reducing pipes on the end of my vacuum cleaner, culiminating in a 1/4" tube which I could insert in the spark plug holes! Needless to say, after half an hour's fishing, I didn't find any. So in the end I started the bike, ready to switch it off immediately if it rattled - but it was fine. I later found out from my local Kawasaki dealer that the dowels served absolutely no practical purpose, and were such a PITA that standard practice was to ditch them at the first service - d'oh!!!!! |
| Alan, Glad you found the leak. One small point though. If you are concerned about bits of silicone getting into you oil system etc. then why decided to run it to get the oil hot so you can drain it?? ![]() ![]() Surely that defeats the object here......or have I missed something??
__________________ Ian DAX 454 Chevy Life is short! Break the rules! Laugh uncontrollably and never regret anything that made you smile. Last edited by slogger; 07-06-08 at 08:51 PM. |
| Quote:
Thinking about it, it's probably better just pour some fresh oil down there to move any debris into the sump, and then drain and change it before starting the engine. I'm 99% certain nothing dropped down though! |
| Surround Sound | Miket | Feedback, Membership and Help | 36 | 11-01-08 10:08 PM |
| Why does my car sound like a Harley??? | bc_suv | Engine Tech Tips & Questions | 12 | 22-10-07 10:17 PM |
| Sound deadening | Tidyshed | Pilgrim Sumo Technical Questions | 14 | 27-08-07 08:26 PM |
| What a sound ! | simon | General Cobra Discussion | 2 | 10-11-06 04:37 PM |
| Wired for sound | hfbradley01 | General Cobra Discussion | 28 | 16-02-04 04:07 PM |
