| Ok, tried sticking a long ratchet extension bar into the thermostat housing in an effort to pry the intake off, only to have the thermostat housing crack under the strain! Sliced through as much RTV at the rear of the manifold as I could... still no joy. Have tried to lever the intake off with a screwdriver, but there's nowhere really to lever on, as the intake is pretty-much flush with the block and heads all the way around. Tried sticking fingers into manifold through the thermostat housing hole and muscling the intake free... STILL no joy (and now my elbow's started hurting!) Any other ideas chaps? I'm really stuck at the moment (and so is my bloody intake). Cheers, Ian.
__________________ 2003 DAX Tojeiro De Dion |
| Quote:
It's also the only way I can remove the roll hoops. They really jam in place so I used nylon straps from the crane to pull them out. Better than a hernia!! Good luck
__________________ Nick Remember - Careless torque costs lives. Last edited by Nobby; 06-06-08 at 07:32 AM. |
| Quote:
Nope, no engine hoist These are the sorts of things you just don't think to factor-in when doing something that should be a '5 minute job'. I wouldn't have expected to need an engine hoist to remove an intake! Oh well. I'm going to try again tonight with a large screwdriver from the front of the intake. Thanks, Ian.
| I have to say I winced when I heard about the levering on the thermostat housing!! You can get long scalpel blades that are also very thin - might get a bit more of the jointing stuff cut between the mating faces - its amazing how many problems you can get from very small amounts of that stuff. I've got an old, wide, blunted chisel that I use for breaking joints like that - it doesn't do as much damage to the mating faces as a screwdriver. Rubber hammer might also help to break any carbonated stuff that is all adding to the sticking power.
| Quote:
I've got a chisel, but it's pretty new and very sharp. Might be worth gingerly trying to tap it between the intake and block though. Will try rubber mallet, too.
| Quote:
| Ian, just picked up on this thread, I know its a pain but be very careful resorting to too much force(dont ask how I know!!) if you have managed to cut or whatever the majority of sealing rtv etc it shouldn't need as much force as you are considering, just dont want to read in a few posts how the bolt holes cracked, have you any movement at all? if there is just rtv holding it then you should have some give albeit small if it is solid there may be something else, is there anyone close to you that can also take a look? just dont lose your rag or it will cost you. Dave |
| I wonder if it would be possible to get hold of 3 scaffolding poles and rig up a tripod
| Drain coolant to remove intake manifold on SBC? | ian_uk1975 | Engine Tech Tips & Questions | 2 | 24-05-08 01:21 PM |
| Ford 302 intake manifold | simon | Parts for sale | 2 | 15-05-08 02:30 PM |
| Which intake manifold? | Dave Williams | Ram Forum | 3 | 07-12-05 04:55 PM |
| Intake manifold: performer vs torker 2 | Patrick | General Tech Tips & Questions | 1 | 21-06-04 09:29 AM |
| Brodix Intake Manifold - No Space for Air Filter | KenT | DAX Technical Questions | 1 | 10-08-03 04:21 PM |
