| Help removing intake manifold Got the carb and thermostat housing off and all bolts out. I was hoping the manifold would just lift off after a little gentle persuasion, but no chance. Can anyone impart any tips on removing the manifold? I notice there's quite a quantity of black RTV around the rear of the intake and this is obviously acting like glue. Cheers, Ian.
__________________ 2003 DAX Tojeiro De Dion |
| double check ALL the bolts are out - so very easy to miss one, and crack a manifold distributor out slice through any thick RTV with a stanley blade gently but firmly pry up the manifold, using a point to lever which wont damage the mating faces when you come to reseal, They are stuck on, but should come off with not much effort
| Quote:
Pete
| Quote:
Saw your other thread earlier... hope you get it sorted. Cheers, Ian.
| Quote:
Cheers, Ian.
| Quote:
Cheers Ian.
| As Steve says,just lever it off slowly with a screw driver. Its just down with the RTV.
| Quote:
Cheers, Ian.
| Drain coolant to remove intake manifold on SBC? | ian_uk1975 | Engine Tech Tips & Questions | 2 | 24-05-08 02:21 PM |
| Ford 302 intake manifold | simon | Parts for sale | 2 | 15-05-08 03:30 PM |
| Which intake manifold? | Dave Williams | Ram Forum | 3 | 07-12-05 05:55 PM |
| Intake manifold: performer vs torker 2 | Patrick | General Tech Tips & Questions | 1 | 21-06-04 10:29 AM |
| Brodix Intake Manifold - No Space for Air Filter | KenT | DAX Technical Questions | 1 | 10-08-03 05:21 PM |
