Old 05-06-08, 10:55 AM
Loctite on head bolts?
Thinking ahead (no pun intended) to when I re-install my heads, should I use Loctite on the head bolt threads? I've read that thread sealant should be used on any head bolts going into a water jacket. Just for 'belt and braces', is there any problem in using sealant on ALL head bolts? If not Loctite (542), which sealant would you recommend?
Ian.
2003 DAX Tojeiro De Dion
Old 05-06-08, 01:28 PM
Ian.
I should add the engine in question is a 350 Chevy.
Old 05-06-08, 01:55 PM
Sidecarbod's Avatar
I don't have a clue about your engine but I do know that what you put on the threads will effect the torque reading so you would be wise to wait for someone to confirm what you should do.
(Even if you are using stretch bolts they have an inital torque setting so you do need to know for sure)
Pete
I refuse to engage in 'ball-bag bothering' with an unarmed opponent.
Old 05-06-08, 01:58 PM
Pete
Thanks Pete. I believe Loctite (or similar) isn't particularly viscous, so shoudn't affect the tightening torque significantly. If thread sealer wasn't being used, you'd probably dip the head bolts in engine oil anyway.
Ian.
Old 05-06-08, 02:35 PM
Thumbs up re head bolts
Ian, dont loctite the head bolts, torque them to the recommended figures and then when the engine has been run up/settled down you can check the bolts again, chances are you will have to retorque a couple which will be a problem if you use loctite, re water jackets I believe a some suitable rtv will suffice, I'm sure there will be more advice shortly. Dave
Old 05-06-08, 02:40 PM
Thanks Dave. Bear in mind the Loctite I'm on about is a thread sealer and not a thread LOCKER. I've seen it advised not to use RTV on head bolts. I must admit, I've done several top-end rebuilds on 4-pot engines in the past and have never used anything on the head bolts and never had a problem. However, I want to follow 'best practice' on the SBC if I can.
Ian.
Old 05-06-08, 03:13 PM
Lloyd Barnes's Avatar
Location: Montgomery, Wales, the only cobra in the village
All the stuff I've read on chevy's recently has been categoric about the need to use thread sealer on the water jacket bolts. If its best practice your after then real steel do some ARP thread sealer specifically for this job. Otherwise one of the books I have also suggests RTV would be ok.
Lloyd B
The wife has agreed and the order is off to Crendon soon. FE motor in the workshop
Old 05-06-08, 03:14 PM
Can't recall if head bolts actually do enter water galleries on the sbc - they don't on a Ford sb, apart from 289s/early 302s from memory.
Once you have a head off it will be readily apparent if the head bolt holes are blind or open to the the water galleries. If the former, you won't need any sealant.
Oops - posted almost at the same time as Lloyd!
My opinion is worth exactly what you paid for it. By the way - I was Right!
Old 05-06-08, 03:23 PM
Hi Wilf
a fair few of them go straight into the jacket. As you say with the heads off its easy to see which.
Just reading the page in question they suggest sealant on all the bolts, perhaps to equalise the torque settings?
Lloyd B
Old 05-06-08, 03:25 PM
Thanks Lloyd... looks like the ARP stuff is the way to go. The page on Real Steel specifically states it's for use with SBC head bolts, so that answers the question
Ian.
BB code is On
Propshaft to reardiff bolts ~ Loctite ? Claus A General Tech Tips & Questions 7 20-12-07 04:26 PM
V8 Head Bolts oldcobber Engine Tech Tips & Questions 10 15-01-07 10:24 AM
Head, Con Rod & Mains bolts dbm10uk Engine Tech Tips & Questions 4 27-08-06 07:11 PM
Head bolts Paul B Engine Tech Tips & Questions 4 17-11-03 12:35 PM
What sealant to use on head bolts? STEVE W General Tech Tips & Questions 5 20-06-03 05:59 PM
