Old 05-06-08, 08:22 PM
Hydro Carbon .. Emissions
As you may have seen, I failed the SVA today on high hydro carbon from the near side bank of cylinders. As I understand it, this means that unburnt fuel is getting into the exhaust manifold. The reading was 3534 instead of 1200 max. So quite high then !! I am looking for any advice that you guys can give me regarding what is causing it. It is not mixture as it is only the left side. (the right is only 123) It is not the tappets as these were checked yesterday. I am hoping that you guys have some brilliant ideas before I start thinking of faulty valve(s) or valve seats etc. I nearly forgot the engine is a Cologne 2.8 V6 from a Ford.
What do you think??
You do not stop playing because you become old; you become old because you stop playing.
Old 05-06-08, 08:26 PM
Clarkson's Avatar
Speed junkie
Misfire or air leak.
David
2nd baby due 23rd Jan.
Old 05-06-08, 08:31 PM
One cylinder not firing - oh he said that already...........
Old 05-06-08, 09:57 PM
badcob's Avatar
Smile
Hi Dave sorry to here the news but its only one thing to sort.could it be the meatering unit .can you check the amount of fuel going to each cylinder .speck
Be bold and mighty powers will come to your aid
Old 06-06-08, 09:11 AM
Thanks for your comments guys, looks like I have to get my big hammer out !!!
Dave
Old 06-06-08, 08:05 PM
Club Sec/Rep Liason
First thoughts would be to get it set up on a Gas Analiser. The Cologne with the Jetronic EFi was a bitch!!! 5' (20th of a degree) turn on the mixture screw can alter things by several % on the CO reading!!! And a low CO will send the HC skyward! As both banks share the same plenum, don't read it as a problem with only one bank.
AK 427 351C T5wc
Old 07-06-08, 03:25 PM
oldcobber's Avatar
Thumbs up
Hi Dave,
Bad luck on the sva.
Could it be ignition related where the fuel is not burnt? Check the plugs to see if one is a lot darker than the others and check inside the dizzy cap for tracking between a couple of the studs. Does the engine still run well?
Bob
Oh go on, darling. Just a few more ££££££`s and it`ll be finished!!!
Old 09-06-08, 09:04 AM
plug gaps can effect how well the mixture burns -
tight - handles high compression - limits revs - reduces effectiveness of burn
wide - strains ht leads, rotor, coil - better emmisions
leaky exhaust valve reduces compression - reduces effectiveness of burn - allows un burnt fuel directly into exhaust
plenty of options with what's been given above as well - all the best hunting
Maurice
Carbon Footprint pat b General Cobra Discussion 7 25-01-08 12:40 AM
Carbon Black Clarkson General Cobra Discussion 0 28-04-07 02:54 PM
SVA & Emissions gareth08 General Tech Tips & Questions 19 25-08-06 10:30 AM
Carbon Cob mark_biddle General Cobra Discussion 4 05-05-06 05:51 PM
Emissions and the SVA Andy302 General Cobra Discussion 17 18-07-03 10:53 PM
