Old 06-06-08, 02:16 PM
RV8 Engine Number
Hi There,
I have an RV8 (Old P6 engine) in my cobra. Can anyone tell me where exactly the Engine Number is located?
Thanks
Martsam
Old 06-06-08, 02:28 PM
Stu J's Avatar
It should be next to the base of the dip stick tube, if it is the same as mine.
C an
O nly
B e
R eal
A drenalin
Old 06-06-08, 02:53 PM
Hi Stu,
Thanks for te reply. Just had a look and there is no number visible. Do the heads need to be off to see the number?
Old 06-06-08, 02:57 PM
Early engines are supposed to of had it stamped on the bellhousing flange at the rear of the block. This is lifted straight out of a Rimmers catalogue
Old 06-06-08, 03:07 PM
Tinka,
Thanks for the reply. The number on there is 35501199. Does that sound like it?
Martsam
Old 06-06-08, 03:24 PM
Yes that looks like it.
Old 06-06-08, 03:29 PM
Thanks Tinka,
How can I find the age of the engine?
Martsam
Old 06-06-08, 04:31 PM
Originally Posted by martsam View Post
Thanks Tinka,
Martsam
This is all I can find but it would make your engine out of a RR Half way down the list
Rover V8 engine numbers
Sorry I cant help more
Old 06-06-08, 05:45 PM
Tinka,
Thanks for your reply. I thought the engine was from a RR. My problem was that I replaced the Pinto engine with this one and took the car in today for an MOT. Unfortunately the garage said I may need to get it SVA'd again before I can ge tit MOT'd as he did not know the Emissions requirements for the rover engine and therefore abandoned the MOT test. Does this sound correct?
Martsam
Old 06-06-08, 09:43 PM
robinj66's Avatar
No - your MOT tester isn't correct.
Assuming that you declared your change of engine to the DVLA (and the V5 shows the correct RV8 ) then ther emissions levels are those set at the SVA. If they are printed on your V5 (page 1, section 3 - "Special Notes") then they apply at all MOT's. If not then the worst thing is that your car is tested to the age of the engine [4.5% CO, HC0.12] or simply a visible smoke test.
If however you haven't declared your change of engine to the DVLA, then I would suggest you do so before attempting to get an MOT.
RV8 engine number stevem General Tech Tips & Questions 2 24-01-08 09:39 PM
engine number? shiney General Cobra Discussion 2 20-01-06 03:44 PM
Engine number jeff Engine Tech Tips & Questions 0 08-01-04 11:07 AM
ENGINE NUMBER andyrich General Tech Tips & Questions 16 15-05-03 08:18 PM
Engine Number On SBF mjculley General Cobra Discussion 7 13-05-03 08:09 PM
