Old 09-06-08, 07:13 PM
Removing head bolts... quick question
Engine set at TDC with #1 piston on its compression stroke. I need to loosen/remove the rockers in order to gain access to all of the head bolts. Do I need to rotate the engine so that each respective valve is cosed before unscrewing the rocker arm nut, or will the act of unscrewing the rocker arm nut gradually release tension in the valve spring?
Ian.
2003 DAX Tojeiro De Dion
Old 09-06-08, 08:04 PM
The latter - just undo them.
Old 09-06-08, 08:19 PM
Thanks wilf.
Loctite on head bolts? ian_uk1975 Engine Tech Tips & Questions 13 10-06-08 10:42 PM
V8 Head Bolts oldcobber Engine Tech Tips & Questions 10 15-01-07 10:24 AM
Head, Con Rod & Mains bolts dbm10uk Engine Tech Tips & Questions 4 27-08-06 07:11 PM
Head Stretch Bolts roger General Tech Tips & Questions 4 05-11-04 09:57 PM
Head bolts Paul B Engine Tech Tips & Questions 4 17-11-03 12:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 Ramblings
