  #11 (permalink)
Old 11-06-08, 04:10 PM
dingocooke's Avatar
[quote=ian_uk1975;249282] 3/8" sockets ARE proper tools last time I looked. I also have 1/2", but don't have 1/2" drive imperial sockets (something I've been meaning to address with an imperial 1/2" socket rail). I must be Superman, cuz I CAN turn the engine over with the 3/8 wrench (but it ain't easy).
QUOTE]
Hehe yep and thats why you'll skin your knuckles eventually, because you'll put so much force onto a puny 3/8 ratchet that it will slip or break (even a snap-on one) and you will at best skin your knuckles and probably bang your head hard as well (I know I did it when I was a callow youf-ouch) pay to learn and all that!!
You can get a good quality rail of AF sockets from a lot of places, and powerbar to make life easier. By the way if the std chevy damper bolts are that weak Id get an unbrako cap head and a big thick washer instead; you wont break that (or a ford damper bolt...)
Hope your on the road soon
Steve
Steve
We're here for a good time...
  #12 (permalink)
Old 11-06-08, 04:46 PM
andicole0's Avatar
It takes how long!
I replaced my damper bolt with one of these made it so much easier to turn over by hand.
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ - http://www.tomsrush.blogspot.com/
Polishes to date = 2.
  #13 (permalink)
Old 11-06-08, 05:03 PM
[quote=dingocooke;249286]
QUOTE]
Steve
Yea, the 3/8" ratchet I'm being forced to use is far from ideal. Will definitely be investing in some 1/2" drive AF sockets very soon.
Ian.
2003 DAX Tojeiro De Dion
  #14 (permalink)
Old 11-06-08, 05:23 PM
Sorry - I missed the bit where you said sorry to Clarkson who told you that to begin with but whose advice you dismissed out of hand"?
  #15 (permalink)
Old 11-06-08, 06:16 PM
Really? I missed the bit where Clarkson said sorry for his sarcastic response. But really, let's not get into any pissing contests, it's quite childish and I'd rather keep things sensible, 'personalities' aside. Thanks.
  #16 (permalink)
Old 11-06-08, 06:30 PM
Clarkson's Avatar
Speed junkie
Not been sarcastic at all??
Only trying to help you my friend as I could not understand why your turning over a V8 engine with a 3/8 drive ratchet!! I have been working in the Motor trade for 18 years, so I should know!
I'll let you get on with it!
David
2nd baby due 23rd Jan.
  #17 (permalink)
Old 11-06-08, 06:37 PM
Saying 'why don't you get some proper tools' isn't the best way of imparting advice!
You're been working in the trade for 18 years and you're very accustomed to working on V8s. This, however, is the first V8 I've done any real work on. My previous experience (in terms of top-end tear-downs) have all been with 4-pot engines, so I have no real frame of reference.
What may seem obvious to you, isn't to me, hence the reason for this thread.
I appreciate you taking the time to respond, but I just took the 'proper tools' comment as a bit out of hand. You probably thought I was being a bit of a numpty, but years ago when you first started, you were probably in the same boat!
Ian.
  #18 (permalink)
Old 11-06-08, 06:44 PM
Clarkson's Avatar
Speed junkie
Ian.
Ok I'm sorry, should have written why don't you use the correct tools.
David
  #19 (permalink)
Old 11-06-08, 07:24 PM
Seems to me that those who need the advice and experience of others might put up with a little rough handling from the aforesaid experienced others if they want their advice for free.
Sorry Ian, sometimes it seems as though we are being taken for granted - if you want our knowledge, be prepared to put up with our "little ways" as well. It is not as if we are particularly difficult, nor offensive. If you can't do that, then I for one will help you no further. Can't speak for others, just how I feel.
You are the one that needs us, not the other way around. You are quite right, you don't want to get into a pissing contest - not while you need us it seems. Once you have solved your problem, how often will we see you contributing here and helping others?
  #20 (permalink)
Old 11-06-08, 07:30 PM
slogger's Avatar
Andi.
Andi m8, get a real size motor and use big tools for the job. No silly little bolts here. I turn mine with the inlet blanked and the outlets tapped. Grrrrrrrrrrrr. Going to get bloody arms like Popeye.
Where's that tin of spinage?!!
Ian DAX 454 Chevy
SBC crank pulley bolt size? ian_uk1975 Engine Tech Tips & Questions 2 20-05-08 08:33 AM
Engine HELP!!....... No key but turning! PORKYMONKS General Cobra Discussion 6 14-05-08 12:35 PM
SD1 Crank Pulley on a 4.6 alastaid Engine Tech Tips & Questions 1 12-12-04 02:02 PM
Tips for Buying an Engine. Andy302 General Cobra Discussion 3 18-07-03 02:52 PM
Engine bay cladding tips needed CobraMat General Tech Tips & Questions 1 04-07-03 08:40 AM
