| Quote:
I did the flow test after install from the pump outlet and still pretty low so if there is a blockage it must be between the fuel tank and the pump but to get access I think I will have to take it to a garage to get it up high as I cant see where there would be a filter between tank & pump. Having been Mondeo/A4 owner for the past umpteen years Id forgotten how much fun spending money, tinkering under bonnets, getting metal splinters and cracked knuckles can be....not |
| Are you doing the flow test before or after the filter king? Try doing it before and after to see if it makes a difference. The filter king is also a pressure regulator so I was wondering if the pressure has been cranked right down. Maybe you could also do a test straight out the pump with a spare bit of hose on the outlet. At least you would have a better idea where the blockage is then. Craig.
| Quote:
| Not sure what kind of tank and pick up pipe you have, but I had a problem with my Dax one. The gauze/plastic filter on the end of the pick up pipe had worked it's way up the pipe, blocking it off quite a bit. Took it out, cut the fuel pipe at 45 deg so the fliter can only slide up so far and not restrict the flow. I think my tank was an MG one with the pick up and sender all together in the side.
__________________ Crendon, Ford Sideoiler 427 |
| Sorry Chris, I missed that bit in your previous post. ![]() It should be fairly easy to see any filters if you can get the car up in the air on a ramp. It could also be a pickup pipe problem in the tank as Neil suggested. Good luck sorting it out. Craig.
| Rolling road | plod | General Cobra Discussion | 4 | 02-05-08 06:50 PM |
| rolling road | pete175 | General Cobra Discussion | 3 | 16-02-08 05:42 PM |
| Dax Rolling Chassis | 427FE | Parts for sale | 2 | 20-01-08 12:07 AM |
| rolling road 4.6 rv8 | fcukruss | General Cobra Discussion | 6 | 08-09-03 02:40 PM |
| Rolling Road RV8 | TINKA | General Cobra Discussion | 26 | 15-08-03 10:15 AM |
