| newbie engine problem - any help would be appreciated.. Hi all, Am on a v steep learning curve with things mechanical so any help would be appreciated. Got a pilgrim mk2 with 1978 ford granada 2.8 cologne lump (carburettor) with a problem. It stutters/hesitates at various iregular points as it goes through the rev range. seemes to be missing occasionally on a cylinder, runs lumpy, and pings/pinks. Its down on power, and takes ages to start (although this might just be down to old engine not started regularly. Car used to be reliable over last 15 years but was left unused for a year in my dads (dry) garage till i picked it up. it took a while to get it started but i thought the 2 hour run down to my place would cure it of the running problems. i filled it with normal unleaded and a shot of lead additive stuff. Battery has lots of juice, car is stored in a dry garage have only run it for 20 minute runs in the dry since the long drive and its still got the problem, I have tried: new plugs (gapped them) new HT leads new distributor cap (old one looked ok and i think rotor tip thingy looks ok) I'm out of ideas (and knowledge - ashamed to say other people have always done my cars for me!!) Timing? (have probably got the gear to do - but would a new thing for me) Wrong octane fuel (next thing I'll try is refilling with super unleaded) Carbon build up? Any suggestions would be really welcome Ta Alex.. |
| I agree with the above. Crud in the fuel system, especially the carb, is most likely. What distributor are you using - electronic or points? The latter can give some of these symptoms - check the points gap and try changing the condensor. It's more likely you have the electronic dizzy - in which case you are limited to using an air line to blow the old Cr*p out and checking that you are getting a decent spark at each plug (take them out and hold them {insulated pliers} against the block with the engine running)
| Quote:
| Quote:
| Redex in tank and in carb as instructed - i agree with others fuel problem needs sorting first to eliminate or cure |
| Quote:
A manual jet clean is the only way, very likely the cause of the problem, and a very simple zero cost fix to boot.
| I agree with everything said above! ![]()
| RV8 engine problem | steve cuthbert | General Cobra Discussion | 10 | 31-07-06 09:12 AM |
| Engine problem....again! | Mr Bling | General Cobra Discussion | 7 | 23-06-06 11:41 PM |
| All Help Most Appreciated | titch | DAX Technical Questions | 3 | 05-01-06 09:17 PM |
| Tools for getting started?....all assistance appreciated | mikwan0929 | General Tech Tips & Questions | 12 | 30-09-05 06:33 PM |
| engine problem help!!!! | simon | General Cobra Discussion | 6 | 09-12-03 07:34 PM |
