| Quote:
| rockers... and check ...,when you have that rocker cover off to pull all the rockers & shaft off ,that one or more of the pushrods haven't poked a hole in the ball/cup rocker arrangement ,as they have a habit of doing..... neil |
| Agree with craig, exactly what I did last night, noisy tappets, try taking off your rocker covers and rotating your crank, at certain points your push rods go slack, one of mine had about 1/2mm rattle on one of them (thats after setting preload at build up) was rattling like buggery. Took the shims out and bobs your uncle, sounds nicer this morning, although Im sure I may have a bearing problem somewhere, but if it gets through the SVA Im not bothered... |
| Hi Ben Always hated the shim idea as you can only set the preload on the entire set of 8 valves to the same level. If you have one tight one and one loose one you can't adjust individually with the shims. I tried them on my 4.2 engine and after a few weeks had rattly lifters. Removed the shims and it sounded 100% better. Another example of RPI selling me stuff I don't need! ![]() Craig.
__________________ Dax Tojeiro, + 355 Chevy + Tremec box = no more money! TWM Fuel injection now up and running! Sounds and runs superb. Polishes to date = 27 |
| Rhoads lifters are renowned for being very noisy - that right there could have been your initial problem. You don't need to replace them with the same.
| Hi Simon, Had a similar noise,turned out to be a bent valve watch had worn the valve guide real badly.Only ran for about 300 mile tops,another 100 and would have recked the heads completely. All the best Dave |
| OK I got it wrong, they are NOT rhoads lifters, just standard ones. The rockers have shims under them, if I find a pushrod looser than the rest and remove the shims, won't it make the others too tight? sorry, I don't underconstumble how they work! |
| Remove all the shims both sides. Yes, the others will be more compressed than the looser one but they so long as they are compressed they should be fine. You have to compress them by 2 or 3mm I think to make them too tight. Rover never fitted shims at the factory so why bother now? Craig.
| I don't want noise!!!!! | alexandervdr | Pilgrim Sumo Technical Questions | 44 | 14-04-09 10:40 AM |
| Tappet pre-load setting | Rupert | Engine Tech Tips & Questions | 6 | 01-02-05 07:22 AM |
| Noisy tappet ? | beanpole | Engine Tech Tips & Questions | 13 | 09-03-04 07:08 PM |
| SD1 'box noise | Brian | Engine Tech Tips & Questions | 3 | 03-04-03 06:45 PM |
| Noise | robert | General Cobra Discussion | 12 | 07-12-02 07:09 PM |
