Old 02-06-09, 06:37 PM
simon's Avatar
Rover tappet noise
Got a rover v8 with a noisy tappety lifter, not awful but annoying. I've done 500 miles since buying the car so it's not likely to go away on it's own now I suppose!
Going to get some new hydraulic lifters, but have never worked on a rover engine before. How far does it need to be stripped down and what bits need taking off. What gaskets do I need to get in before I start? anything else I should look for?
Any advice much appreciated.
Simon
Old 02-06-09, 06:47 PM
dinosoar's Avatar
Carb off.
Water drained.
Inlet manifold and valley gasket off
Cam and lifters fully on view.
To remove lifters you need to;
rocker covers off.
Rocker shafts off.
Pushrods out retaining order.
You can now remove the lifters for inspection.
Andy.
Old 02-06-09, 07:22 PM
Club Sec/Rep Liason
Originally Posted by dinosoar View Post
Carb off.
Water drained.
rocker covers off.
Rocker shafts off.
Andy.
But before you do that. Make sure it's not just a chuffing exhaust header gasket/loose bolt. They sound very similar
AK 427 351C T5wc
Old 02-06-09, 07:49 PM
Dixie's Avatar
Carb off.
Water drained.
rocker covers off.
Rocker shafts off.
Andy.
plus you will need a new manifold gasket. They are one use only.
OLD IS:- When a man is warned to slow down by a doctor instead of a policeman.
Old 02-06-09, 08:10 PM
ƃuılıǝɔ ʎɯ ɟɟo ʇǝƃ`lǝuoıl
What do you know about the history of the engine?
Changing just a lifter on an existing cam is a bad idea as it can just cause accelerated damage to the cam.
Lift the rocker covers off and take a look at the state of the rockers. It might need new rockers and shafts as these wear out quite nicely although if they are worn then take a look at the state of the rest of the motor as it's probably the same way.
If shims are fitted underneath the rocker pedestals, remove them. They are pointless.
Oh, and check the exhaust and other things as suggested first.
TWM Fuel injection now up and running! Sounds and runs superb.
Polishes to date = 27
Old 02-06-09, 08:15 PM
simon's Avatar
Rover 3.5 engine, fully rebuilt 4000 miles ago (1996!) stage 1 heads, hurricane cam, uprated oil pump, electronic ignition, offy manifold Holley carb.
Engine runs sweet as a nut, pulls strongly etc, just slight tappety noise (definitely not exhaust gasket)
Old 02-06-09, 08:18 PM
stevey's Avatar
sorry to p8ss on the parade here BUT if you change the lifters you will need to change the camshaft as well, check what the other contributors have suggested first
Euro 427
Rover 3.5 V8
worried about my carbon footprint-- need to make it bigger!
Old 02-06-09, 08:24 PM
Sounds quite a good engine then, Or at least should be.
Did you build it? If not my first look would be for shims under the rocker pedestals. This only requires removal of the rocker covers so not a big job.
I assume oil pressure is fine?
Old 02-06-09, 09:04 PM
Clarkson's Avatar
Half arsed=half fast!
Sounds like a cam lobe has gone flat or those dodgy anti pump up lifters.
David
SRV8
New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign.
http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E
"Buy a Toyota, it drives itself"
simon's Avatar
Oil pressure 50lbs at startup, 25lbs idle 45-ish running
I thought you had to change the lifters if you changed the camshaft, not the other way round?
Old lifters wear a new cam but new lifters don't wear a cam in good nick...isn't that right?
Simon
BB code is On
I don't want noise!!!!! alexandervdr Pilgrim Sumo Technical Questions 44 14-04-09 10:40 AM
Tappet pre-load setting Rupert Engine Tech Tips & Questions 6 01-02-05 07:22 AM
Noisy tappet ? beanpole Engine Tech Tips & Questions 13 09-03-04 07:08 PM
SD1 'box noise Brian Engine Tech Tips & Questions 3 03-04-03 06:45 PM
Noise robert General Cobra Discussion 12 07-12-02 07:09 PM
