| Stalls when I brake hard!? Er I've got a new, weird, problem, if I brake hard, the engine stalls. (Pilgrim mk2 with 2.8 granada, carb, manual box) Idle sounds fine, & doesnt change if I'm stationary and put my foot on the brake. Nothing changes in terms of engine rpms etc for medium & light braking but hard/emergency braking (even with my foot on the clutch before starting to brake) it just stalls. Restarting isnt a problem. Not sure how long I've had the problem for as I tend not to do hard braking - only noticed it as I've got an issue I think with a caliper on the front - it pulls to one side. |
| Quote:
Alfie B
__________________ Heart of Gold Nerves of Steel Knob of Butter |
| My Edelbrock 4 barrel carb used to do that on my Chevy and it was seriously rich when trying to re-start it showing it was flooding. I checked the float levels according to the manual and they were fine. Common opinion at the time seemed to be that is a feature of the Edelbrock carb. My solution was to spend thousands of pounds and put EFI on the engine! Craig.
__________________ Dax Tojeiro, + 355 Chevy + Tremec box = no more money! TWM Fuel injection now up and running! Sounds and runs superb. Polishes to date = 27 |
| I had the same problem and like the others said the float level is the prime suspect, but you might also try to stiffen the front end ( if you have adjustable dampers ). If this does not help you might check the fuel pressure ( needs to be around 5,5 psi at least with edelbrock carbs ). Yours sincerely, GB |
| Hard to Believe Ive done it | Toddy | General Cobra Discussion | 13 | 11-03-08 07:23 PM |
| Hard Top | MartinM | DAX Technical Questions | 39 | 31-12-07 09:25 AM |
| Hard top | j9kks | General Tech Tips & Questions | 3 | 10-04-05 09:27 AM |
| Why it's hard being a man | robert | The Cockpit | 3 | 30-12-04 08:45 PM |
| Ford 2.8 Auto - Stalls | andrewbailey | Pilgrim Sumo Technical Questions | 2 | 07-05-04 08:17 PM |
