| Quote:
Alfie B
__________________ Heart of Gold Nerves of Steel Knob of Butter |
| Quote:
__________________ AK Gen II, the banging, drilling, swearing and questions has commenced |
| Quote:
| Quote:
| Quote:
just noticed another couple of other things though.... the fuel feed goes from the regulator acoss the left bank, under thermostat housing then down side of carb, is this the normal route? two plug leads seem to go out of sink n the distributor i.e. they go to he opposite side of the distributer to the bank they are on and are different to the other leads on their side. i'll try to attach a photo to explain better
| Quote:
| Quote:
does it matter if the fuel line comes in from the rear of the engine feeding the Carb from the secondaries end? I just like to keep fuel pipes to the shortest route possible so there is less pipe to have problems. thinking of also moving the expansion tank if i can as i have a hose coming straight over the engine from one corner of the bay to the opposite corner at the rear. love the car and learning loads just tinkering with it. Checked the suspension yesterday and every corner was on a different setting, not just 1 or 2 clicks difference either!! set them all at 10 clicks and see how that goes. just deciding whether to spray the wheels silver or leave them black. don't want to spend a fortune on new wheels unless it would significantly raise the re-sale value for when want to sell it.
| I think I would be concerned if my RV8 had oil pressure of 100 psi when hot. As Alfiebeard has already said, you are likely to cause swift damage to your distributor drive unless you have already fitted a secondary oil feed. The pre-1994 engines with distributor driven oil pump (as opposed to crank driven on the later engines) should have a pressure of 35 psi at 2400 revs (I think the crank driven ones are slightly higher but use "thinner" oil). Looking at your previous thread, you already appear to have suffered with a worn dizzy drive (Rv8 Died On Rolling Road Today ). You might also want to have a look here (www.v8forum.co.uk :: View topic - Rover V8 cam gear wear ). A worn distributor drive might also explain why your dizzy was misbehaving on the Rolling Road - see the second page of the secong link.
| Oil Pressure Too High?? | Dutch Paul | Engine Tech Tips & Questions | 41 | 11-08-06 11:45 PM |
| Oil pressure too high when cold ? | David Horsnell | Engine Tech Tips & Questions | 12 | 08-04-05 05:30 PM |
| Oil pressure to high ?????????????? | pat b | General Cobra Discussion | 10 | 09-12-04 02:31 PM |
| High mileage LS1 | Robin427 | General Tech Tips & Questions | 3 | 28-12-03 09:44 PM |
| High Mileage | iaincobra | The Cockpit | 5 | 07-03-03 02:11 PM |
