| Lloyd it is all to do with different torque and power curves that can be obtained in the States in Pro stock Warren Johnson made major advances when he debuted a flat plane cranked engine which effectively had a different firing order (made it sound like a V6 IMHO) it is a black art and best left alone if you want more power just fit this!
__________________ Euro 427 Rover 3.5 V8 worried about my carbon footprint-- need to make it bigger! |
| Quote:
When I built it I toyed with using a roller cam. I didn't go for it in the end as had already ruined the budget with the heads
__________________ Lloyd B Dedion Dax/Clarkson 383 Chevy with roller 4/7 swap cam, AFR195 heads Before you judge a man, walk a mile in his shoes. After that who cares? He's a mile away and you've got his shoes |
| Dave Vizard did a lot of research on the 4 - 7 firing orderswap in a couple of his V8 tuning books. Seems there are some benefits and a small power increase if done right. May be worth it for a few BHP though? Hot Rod did some tests to see if it really did make a difference. Testing Lunati Cams - Intake Manifold - Results Of the Dyno - Hot Rod Magazine This article is based on Lunati cams and was published a while ago but it's worth a read
__________________ Nick Change is inevitable, except from a vending machine. |
| I have a roller 4/7 swap in my chevy, and it goes really well. The idea behind it is better fuel distubtion in the intake manifold. Google it.
__________________ David SRV8 New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign. http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E "Buy a Toyota, it drives itself" |
| Quote:
Seems like opinions is really split as to whether they work or not.Where did you get yours from Dave and what spec is it? Seem to remember you're running AFR195 heads as well.
| Quote:
It was a 230/236 at .50 on a 110LCA with .510 lift. Yes I'm using AFR heads made 420hp at 6100rpm and 415lbft at 4,600rpm not bad for a mere 350ci on std bores. Might not be every one's idea of a nice street motor, but was really quick once you have wound it up!! If you have a 383 with the same cam it would be really nice maybe peaking 500rpm earlier. Of the shelf cam, the 270xe roller is my faviorte profile for strokers. Anything over 230 and your loosing good street manners for little gains above 5000rpm.
__________________ David SRV8 New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign. http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E "Buy a Toyota, it drives itself" Last edited by Clarkson; 01-07-09 at 04:26 PM.. |
| Rover firing order | simon | Engine Tech Tips & Questions | 7 | 18-05-09 07:58 PM |
| Firing order for Rover V8 | Dixie | Engine Tech Tips & Questions | 3 | 31-07-08 08:54 PM |
| LS Firing Order | mylesdw | Engine Tech Tips & Questions | 15 | 22-04-06 08:36 PM |
| Chevy 350 firing order | Frosty | General Tech Tips & Questions | 13 | 24-11-05 10:16 PM |
| Ford 302 firing order??? | cgnw28517 | General Tech Tips & Questions | 8 | 10-07-01 10:46 PM |
