Old 01-07-09, 10:18 PM
383 stroker's Avatar
idling increases with temp
I have set my idling at around 800 rpm (383 stroker/edelbrock rpm performer combo). When the engine is started from cold it is fine. After a run the idle varies from 1000 to 1200 rpm. After an exhuberant drive last Thursday the exhasts startet to pop/on the overrun (i have'nt checked the header bolts for tightness but will do as i have had to nip them up once already) and on the run back home i got caught up in the usual M25 snail crawl. The car was kangaroo'ing at slow speeds up to about 40 if i tried to keep a constant speed but was happy if pressed on.
Now could these symptons be:
a) air/fuel ratio related
b) timing
c) ?????
As the car is off the road for diff change and dashboard upgrade isa there anything that may need a look/poke about whilst i have it in bits again (typical timing issue with the weather so good).
As always your advice/jibes/cracks and ridicule is much appreciated
Thanks guys in anticipation.
kind regards
Andy
2008/9 Dax De Dion, tremec TKO600, 383 stroker .Smiles and miles 2100+ since April 2009/petrol loads (i should have gone for a desiesal!)
fuel tanks x3 / Diffs x2/ dashboard x2/wind wing x1!/Dizzy x1/Alternator x1
polishes x6
WATCH THIS SPACE FOR THE NEXT FAILURE!
Old 01-07-09, 10:21 PM
Clarkson's Avatar
Half arsed=half fast!
b) timing
c) ?????
Too lean idle mixture, richen it up a little.
David
SRV8
New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign.
http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E
"Buy a Toyota, it drives itself"
Old 01-07-09, 10:23 PM
Miket's Avatar
Extremely Senior Member!!
And 17 more polishes to catch up to Graggle
Mike
Cobraless
I have a simple philosophy: Fill what's empty. Empty what's full. Scratch where it itches.
HONDA ACCORD FOR SALE
Old 01-07-09, 10:34 PM
Clarkson's Avatar
EH?????????????
David
SRV8
Old 01-07-09, 10:39 PM
Fuel Conservationist.
Yeah, but I took my car out for a spin tonight so you can guess what I'll be doing tomorrow night, Better make that 18 more polishes!
(It's in Andy's Signature David)
Where were you anyway tonight David? Thought you might have come along to the Cowdray?
TWM Fuel injection now up and running! Sounds and runs superb.
Polishes to date = 27
Old 01-07-09, 10:41 PM
Thanks David and Mike I'll get the big screwdriver out. David hint on my sig .. only 2 polishes! So far!
kind regards
Andy
polishes x6
Old 01-07-09, 10:49 PM
Clarkson's Avatar
Sorry did not read the signature
I forgot all about tonight
My messanger never told me.
David
SRV8
Old 02-07-09, 10:26 AM
Neil O's Avatar
Andy, check your dizzy cap first. Mine was doing the same rapid idle, then it would not want to tick over properly/at all.
It was dirt and damp in the top of the dizzy and the advance mech was sticking. I washed it out with WD40 and it was fine.
Credit where it's due, Wilf told me to look there first.
Crendon, Ford Sideoiler 427
"Some cause happiness wherever they go, others whenever they go."
Oscar Wilde.
Old 02-07-09, 03:06 PM
BLOKE's Avatar
Neil, I had a similar problem with my SR V8/ 351 Windsor, had to buy a new dizzy cap, it was water going in the scoop, and dropping into the dizzy, I have now blocked up the scoop. I had to buy a new cap as the contacts were coroded.
Popping I think will be loose headers, nip them up, but dont overtighten them, you may have to do this a few times before the gaskets stop compressing.
Regards Frank Dowsett. BLOKE.
Old 02-07-09, 04:53 PM
cliffords's Avatar
Andy does the idle change with the clutch in or out ?
David Clifford
AK427
BB code is On
My FASTCO Engine just idling Sparticus General Cobra Discussion 39 31-12-07 04:33 PM
weber 500 idling ceejayjay Engine Tech Tips & Questions 3 09-10-07 07:28 PM
Running and idling oil pressure mightyyid Engine Tech Tips & Questions 3 18-07-06 04:00 PM
Dax Price Increases. RANS General Cobra Discussion 4 14-10-05 08:04 AM
Holley 4160 600cfm VS idling set-up questions ian General Tech Tips & Questions 9 16-07-03 11:35 PM
