Originally Posted by
Loco
Ok - I've made some progress over the last few days and have got the engine and gearbox out and started taking bits apart. Suprised I didn't have any problems: the timing chains is loose as hell, there wasn't a thermostat which explained why it took a week to warm the engine up and the wiring behind the dash is horrific!
So while I'm waiting for the engine to come down I'm going to have to spend a lot of evenings getting the wiring up to scratch. I've got a decent 'blade' fuse box, so will transfer the circuits to it systematically, tracing them all out and making them good as I go along (replacing connectors with solder/heat shrunk joints, replacing switches, etc).
First question: I've been seeing a lot of threads about keeping the Rover v8 cool I'm going to have a 74C thermostat and a 88-83 thermostatic switch on the radiator (am I correct in saying this should be in the top hose coming from the hot engine?). My radiator measures ~620 x 320 x 45mm (ie 2 x 1ft x 1") which seams a little small - is this going to be sufficient to cool a moderately tuned 4.6L Rover V8? It has a single 12" fan with a cowl that covers probably 2/3 of the rad area.
Finally, there's a rather horrible plastic 'bearing' that is used to clamp the steering column in place to the chassis. It was loose, so I could just tighten it up, but do you know where I could get an altenative or direct replacement for one of these? Steering column diameter is 14mm:
Thanks, all!
Something like this would be better SBPP202 Pressed Steel Pillow Block Housing with 15mm Insert Simply Bearings Ltd
AK427 351Cleveland T5WC
Bookmarks
