Looks ok to me, clean the idle air jets on top of the carb next to the squirters, tiny jets with a little hole in them that could have carbon around them, failing that remove the float bowls and blow out the idle jets (depending on carb) if no jets there is a tidy drilling on the metering block.
1.5co is too lean at idle.
LinkBack URL
About LinkBacks
Bookmarks
