Results 1 to 4 of 4
  1. #1
    Ian C's Avatar
    Ian C is offline Head Mechanic
    Join Date
    Dec 2008
    Location
    Newcastle upon Tyne
    Posts
    776
    Rover V8 Compression Ratio - expert advice needed
    Hi,
    I am on the same road as jonny m (see thread “Rover V8 Cylinder Head: Minimum Thickness) but I thought I would start a new thread as I have slightly different issues.
    My engine is a 1992 3.9 RV8 from a Range Rover Classic, the block is stamped 9.35:1 and the head thickness (dimension A) is 0.93”. The Rover manual states this should be 0.94” – new so it would indicate that the heads have been skimmed by 10 thou !? However the face of the cylinder heads does not support this as it appears to have original casting marks still evident (see picture 04).
    I have measured all the volumes above each piston (when at TDC) and have calculated the volume of the composite gasket (thickness 1.2mm before compression). I am currently measuring the volumes of the combustion chambers prior to establishing the current CR. The first combustion chamber volume (CCV) came out at 33.7cc giving a CR of 9.17:1. The engine has been rebored +20 thou so, in theory, the CR should have increased by approx 0.1:1.
    My questions are –
    Has the cylinder head been skimmed or were there variations in the “A” dimension when new?
    Is the measured combustion chamber volume of33.7cc “normal”? – I was expecting either 28cc or 36cc.
    Is the quoted CR of 9.35:1 accurate or does it vary from engine to engine? and, if so, by how much?
    Any and all input appreciated.
    Ian
    Pilgrim Sumo Mklll (build started Jan 2010); RV8 3.9 EFi ; LT77; Granada Diff & Suspension
    Apr. 2013 - Engine in, rolling chassis progressing
  2. #2
    kdavies3's Avatar
    kdavies3 is offline Driving God
    Join Date
    May 2004
    Location
    Cowbridge, Vale of Glamorgan, South Wales.
    Age
    55
    Posts
    6,851
    The accuracy of the 9.35:1 should be within 0.01 cr.
    You need to work with the compressed thickness of the gasket.
    If the heads have been skimmed it will have been on the bottom face.
    Kev Davies
    South Wales Area Rep.
    DAX Mk4, 383 Chevy Stroker, Tremec. SOLD
    Contemporary CCX 3-4028, 445ci Big Block FORD FE, Old School Now Running and Driving
  3. #3
    Ian C's Avatar
    Join Date
    Dec 2008
    Location
    Newcastle upon Tyne
    Posts
    776
    Quote Originally Posted by kdavies3 View Post
    . . You need to work with the compressed thickness of the gasket.
    Kev,
    Thanks for the response. I have assumed (always dangerous) that the composite gasket will crush from its relaxed thickness of 1.2mm (0.12cm) to 1mm (0.1cm) when in place and the cylinder head torqued to the correct setting – is this reasonable?
    You can see the bottom face of the cylinder head in pictures 3 & 4 – does it look like it has been skimmed?
    Ian
  4. #4
    Sidecarbod's Avatar
    Sidecarbod is offline Driving God
    Join Date
    Mar 2006
    Location
    Location Location is a crap TV program
    Posts
    6,557
    Personally I would not worry too much about any figures that Rover state, their engines came off a production line and therefore all sorts of things could varry.
    You are doing the right thing by measuring the volumes, 0.2mm compression of the gaskets seems like a reasonable figure, you could go for 9.75:1 if you want to stick to plain unleaded or 10:1 if you don't mind using Super unleaded. Of course other things affect the actual CR, mainly the camshaft.
    AJMHO!
    Rules for buying 'Go Faster' parts:-
    If it's fast and cheap then it's not good.
    If it's cheap and good then it's not fast.
    If it's good and fast then it's not cheap!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
