Old 02-02-03, 04:56 PM
RV8 crankcase venting
Can anyone give advice on how to correctly vent crankcase pressures on a supercharged RV8?
Before fitting the s/c I vented to a catch tank only. After a thrashing quit often the dipstick was released through pressure build up in the crankcase.Clearly this situation will be much worse with the s/c fitted.
Should I vent into the s/c intake area or will this draw too much pressure from the crankcase?
Any thoughts?
Thanks,
Baldric
Baldric
Old 02-02-03, 09:24 PM
russell_ram's Avatar
Club Treasurer
RE: RV8 crankcase venting
Barry,
I wouldn't vent into the sc intake. You don't really want all that crap going into the sc rotors do you? I would think you need better venting of the catch tank with big bore feeds from both rockers. Alternatively you could fit a (brake) vacuum pump from an old diesel (used to feed the brake servo), then you could ensure crankcase vacuum - might even reduce the losses of moving all that air up and down underneath the pistons. You get this effect for nothing if you run a dry sump system.
Russ
Old 03-02-03, 08:44 PM
Thanks Russ,
I`ll try the dual vents & drill more holes in the catch tank first.
Baldric
Baldric
Old 05-02-03, 06:47 PM
Banned
Barry, I made two take off's one for each rocker cover, going to a specially made ally block, too which I fitted a PCV valve which I got from Real Steel. Then into the intake with T peice via the sevo pipe under the carb. Air is then draged in at the front of the rocker covers through Morsco breather/fillers. You could still use your tank with the valve between tank & inlet manifold. As Russ say's that way you get rid of the cr#pp but not via the blower.
My car now is a little week on tick over but system seems to work okay once throttle applied Eric.
Old 05-02-03, 11:44 PM
Take at look at how the drag guys do it, go to www.summitracing.com and search for part number MRG-6002 or MOR-25900 (same thing) very simple, tidy and you should be able to make your own if you like.
Fuel tank venting nbracken General Tech Tips & Questions 18 21-06-07 12:43 AM
Crankcase evacuation steveatyork Engine Tech Tips & Questions 1 29-11-06 09:20 PM
Crankcase breathers & powerloc diffs ColinH General Tech Tips & Questions 11 19-11-04 08:51 AM
Non venting locking fuel cap David Horsnell General Tech Tips & Questions 1 18-09-03 05:46 PM
Fuel Tank Venting martin DAX Technical Questions 3 26-04-03 03:07 PM
