| RE: Unleaded Paul Russ will correct me if I'm wrong but I run my 3.5 on unleaded with no problems.i was led to believe the rover heads had hard valve seats from years back. Steve G GE427-Rover 281ci.
__________________ Regards Steve G GE427(Rover 281)Not blue-well a bit. |
| RE: Unleaded Steve I had a reply from another forum this afternoon that unleaded superplus should be ok Any ideas? Just a thought Paul
| RE: Unleaded I see Thanks Russ Another quickie - Can the "rope" crank seals on a P6 be upgraded to more modern types? Is there a kit or something or does it involve machining? Just a thought Paul
| RE: Unleaded Paul, No, sorry they can't - or not without re-machining the rear of the block and rear cap. I know it's a bit late now but the P6 block isn't really the best place to start if building a Rover engine. Having said that the rope seal is not really a problem if installed properly - if you can get it not to leak from the start then it shouldn't for 100,00 miles! Russ |
| RE: Unleaded Thanks again Russ I`m just doing my homework before I start collecting bits and pieces.Looks like I should be searching for an SD1 rather than P6 engine then. Just a thought Paul
| Unleaded petrol | johnpower | General Tech Tips & Questions | 7 | 06-08-07 01:45 PM |
| Run on Unleaded | robinj66 | Engine Tech Tips & Questions | 7 | 07-10-05 09:52 PM |
| leaded vs unleaded | revfeim | General Cobra Discussion | 10 | 06-09-05 02:53 PM |
| rv8 unleaded heads | craigh | Engine Tech Tips & Questions | 3 | 22-12-04 04:19 PM |
| Rover V8 and Unleaded | hayterp | Engine Tech Tips & Questions | 3 | 23-03-04 07:22 AM |
