| which coil ? My 3.5 came complete except for the coil. I have the ballast resistor and the 35DE8 distributor. All the connection blocks etc seem to match up with the haynes manual but I am still a bit concerned as to how I should connect the lot up. Will any coil from Halfords do ? Steve |
| Re: which coil ? Look on the Demon tweeks site, they list coils and which to use with what, can e mail them if need advice, Nigel. |
| Re: which coil ? Martin, Is it really that simple? When I first put my car on the road it would drive well for about 10-20 mins then start misfiring and eventually stop. Add 1 ballast resistor and the problem disappeared. David
__________________ David Large Bald Surfer with a BRA 289 |
| Re: which coil ? Hi David, If all you did was to add a ballast resistor than your problem was in that you were using the wrong voltage coil ! and as it got hot ( too higher voltage applied to it ) it would start to break down. As long as the coil is a 12v coil it is a much better idea to simply get rid of the ballast resistor. IMHO :thumb:
| Re: which coil ? David, as Martin said you were/ are probably running a 6 volt coil not 12v. This would over heat after a while on 12v, hence the need for a ballast resistor. Just fit a 12v coil and no ballast. :thumb:
| 12 V coil | jeff | General Tech Tips & Questions | 5 | 16-03-06 07:06 PM |
| MSD coil | Clarkson | General Cobra Discussion | 38 | 27-02-06 06:28 PM |
| Coil over shocks | mouldb | General Cobra Discussion | 0 | 27-02-05 10:35 PM |
| Coil over shockers | mouldb | Pilgrim Sumo Technical Questions | 0 | 27-02-05 10:04 PM |
| RV8 Coil | stu e | Engine Tech Tips & Questions | 0 | 01-02-05 05:34 PM |
