Old 16-05-03, 12:49 AM
Cam shaft
I have a re-built RV8 engine, not by me, sat in my Sumo chassis.
It has been re-built useing a standard cam. I would like to fit a Typoon cam or similar.
Question is, after reading the Haynes manual, Is this advisable.
They make a lot of the fact that the cam shaft bearings could be damaged when removing/re-fitting the cam shaft.
Any thoughts?
Old 16-05-03, 08:31 AM
STEVE G's Avatar
RE: Cam shaft
No problem taking out and re-fitting but look on one of the Rover type sites for the right cam for you.Try RPI's site.
www.rpi-engineering.co.uk
Steve G {-}
GE427-Rover 281ci.
Regards Steve G
Old 16-05-03, 04:04 PM
RE: Cam shaft
easy as peas if you careful... I should know I did it and I dont know what Im doing! :P
kreativejuice...
www.kreativejuice.co.uk
Prop Shaft digger782 General Cobra Discussion 5 30-11-07 05:01 PM
Prop shaft next cliffords AK Technical Questions 5 17-07-06 07:14 AM
Prop Shaft BenBaron General Tech Tips & Questions 11 15-06-06 04:02 PM
Is my shaft long enough... Grease Monkey General Tech Tips & Questions 7 07-09-04 01:14 PM
Rocker shaft dave jenkins Engine Tech Tips & Questions 9 30-08-03 11:57 PM
