| Crnkshaft damper wobbling. Hi all, ive just noticed that my crankshaft pulley and damper wobble. It can only be seen at low engine speeds. Is this normal? I rebuilt it a few years ago, ive checked the reatining bolt and its tight. Phil
| RE: Crankshaft damper wobbling. Cheers Martin, actually took damper off yesterday and spun it up in the lathe. It was wabbling by 20thou. Rang rpi and they rekon thats OK. I wasnt happy with that so ive clouted it a few times to get it running true, its only held on with some rubber. Then spot welded it in place. HAve put it back onto car but now carnt seem to get the retaining bolt tight, the car keeps moving even if i chock the wheels up. Im going to have to get it over a pit and chock it up better. Phil
| RE: Crankshaft damper wobbling. Hi Phil, stupid question, but which gear have you put the car in? If you put it into 5th with the handbrake on tight, you should not move it at all. Martin :tu :tu
| RE: Crankshaft damper wobbling. Hi Martin, ill try that, i think i was in 1st. Phil :tu
| Damper | john cohen | General Cobra Discussion | 4 | 13-12-05 08:19 PM |
| AK Damper Settings | choogh | AK Technical Questions | 1 | 14-06-04 10:55 AM |
| AK damper adjustment | andyrich | General Tech Tips & Questions | 0 | 15-06-03 10:44 AM |
| AK damper adjustment | andyrich | AK Technical Questions | 2 | 08-06-03 09:56 PM |
| Damper Instalation | lardy | General Tech Tips & Questions | 0 | 05-03-02 10:32 AM |
