| RE: Rover V8 holley size? A Holley 390 is perfectly adequate for your motor. Formula is (cubic inches/2)*(max rpm/172 60 cubes per liter, Volumetric efficiency around 80-85%. Do the sum and you'll end up showing a requirement for a 350- ish cfm carb. (VE=0.85, max rpm 6000). Fitting a large carb will just reduce the air flow rates through the carb ruining fuel atomisation and making it difficult to tune and, in the extreme, reducing the vac to a point where the secondaries might not open correctly. Double pumpers will be even worse. If you want a carb that leaves 'headroom' for more revs, capacity or tuning later, then go for a 465 Holley or 500 Webber as Steve says. Russ |
| Holley help? | CobraRV8 | Engine Tech Tips & Questions | 0 | 04-06-07 11:29 AM |
| 950 Holley | keane | General Tech Tips & Questions | 10 | 22-02-07 05:44 PM |
| Rover SD1 radiator size? | _martijn_ | Engine Tech Tips & Questions | 15 | 23-01-07 06:01 PM |
| Unwanted rev. limit on Holley fed Rover V8 | wires | Engine Tech Tips & Questions | 7 | 16-04-04 08:30 PM |
| Rover V8 Clutch cylinder bore size | hfbradley01 | General Tech Tips & Questions | 2 | 15-02-04 09:27 PM |
