| Do I need a Ballast resistor with my mallory dual point?? Do I need a Ballast resistor with my mallory dual point?? what do they do anyway? cheers Ben |
| RE: Do I need a Ballast resistor with my mallory dual point? Cheers Russ, I say Bo**ox to it then, anything that makes it more complicated will only allow me to 'almost' start more fires :P I say almost cause that what was happening when I didnt know what wires went where, so I guessed with a method of suck it and see. Saw lots of smoke as I burnt out the wires in my dizzy DOH! |
| Re: Do I need a Ballast resistor with my mallory dual point? If you dont run a ballast resistor with your dual point the points will last about 1000 miles if you're lucky. You could run a Hyfire ignition unit with it and that gives you a full electronic system with added spark ooomph and digital multi-spark up to 3300rpm. I've got a couple of spare brand new units, if anyone is interested pm me.
__________________ Rover V8. 3.8ltr, 3.5 block, 4.2 crank, 12:1, propane, stg3 heads etc, 295bhp Rover V8. 4.8ltr, 4.6 x-bolted block, stroked 4.6 crank, blah blah, 410bhp Rover V8. 3.8ltr as above but with Eaton M112 running propane only @ 14:1....anywhere between oh my god and oblivion bhp. Latest project is a Buick 455 into a Classic Range Rover www.hardcore4x4.co.uk |
| Re: Do I need a Ballast resistor with my mallory dual point? As Rossco said, if the coil needs a ballast, things won't last long if you run without one. You can just wire the ballast permanently in series with the coil and not worry about the start-up bypass wiring. If you go for an electronic system, even the simple type that use the points as a trigger you can chuck out the leading point set from dual-point set up and run with one. Much simpler.
| Re: Do I need a Ballast resistor with my mallory dual point? Hi there I run a dual point with a Mallory 12V coil through a Ballast resistor. Have done away with the 12V bypass and it starts first time every time. Phil |
| Re: Do I need a Ballast resistor with my mallory dual point? Phil: if it really is a 12V coil you don't need the ballast resistor at all.
| Re: Do I need a Ballast resistor with my mallory dual point? I'm running a Mallory Dual Point Dizzy. If you run them at 12V they get through points and condensers at an alarming rate!!! Cheers Phil |
| Ballast resistor ?? | bitsilly | General Cobra Discussion | 6 | 09-05-07 11:09 AM |
| Ballast resistor | cliffords | General Cobra Discussion | 4 | 08-03-07 08:27 PM |
| dual point mallory dizzy | fletch | Engine Tech Tips & Questions | 5 | 24-07-06 11:24 AM |
| Mallory Dual Point Distributor | Marty V6 | Engine Tech Tips & Questions | 2 | 02-07-04 11:40 PM |
| Ballast Resistor | millsd60 | General Tech Tips & Questions | 3 | 07-04-02 11:34 AM |
