| 4.6 rv8 running temp(what should it be?) as per heading can someone tell me the temp that the fans should cut in at.they are set to cut in at 60c.seems a tad low to me,but any feedback appreciated. |
| RE: 4.6 rv8 running temp(what should it be?) If you have adjustment, the way to set where the fans cut in is to run the car to operating temp on the road so that cooling air gets to the rad, with the fans switched off. Note the temperature on the temp gauge, this is the normal operating temp. Then run the engine on tickover or just above with the car staionary, so no cooling air gets to the rad, monitor the temp and set the fan to cut in when the temp gauge reads a bit higher than normal and check that the fan cutsoff when the temp goes back to normal, there is normally a bit of hysteresis in the control to allow for this. As Russ says the engine operating temp is set by the thermostat not the fan switch. Kev |
| Running on - what causes it? | nbracken | General Tech Tips & Questions | 20 | 17-04-08 08:32 PM |
| Anybody running IE7? | dave | General Cobra Discussion | 17 | 28-11-06 08:54 PM |
| 302 Running Hot | Rowie | General Tech Tips & Questions | 17 | 18-10-04 11:19 PM |
| Running In? | tonym | Engine Tech Tips & Questions | 2 | 14-07-04 01:36 AM |
| 383 new!.....in and running!!!! | radicalradam | General Cobra Discussion | 12 | 20-11-03 07:11 PM |
