| Head bolts I know I have read somewhere that certain head bolts were omitted from later engines and that if heads are removed and replaced on earlier engines, these bolts should not be fully torqued up. Can someone please advise which bolts are we talking about and what should the new torque be ? I am using a 1976 SD1 and will fit composite head gaskets. Thanks guys. |
| RE: Head bolts Composite head gaskets will lower your compression ratio, ( I think by 0.5) so if you've already got a lowish cr you might think about skimmng the head. RPI reckon that the 4 outer head bolts on the earlier engines with 14 bolts should be torqued to about 25ftlb. Cylinder head bolts should be torqued to 65 to 70 ftlbs, don't forget a smear of oil on the threads when torquing them down. regards Kev |
| RE: Head bolts Thanks for the info guys but, I may be a little slow here, which bolts are classified as the outer 4 bolts ? Do you mean the two forward and two rear outboard bolts on each head? Any chance of a photo ? What impact will lowering the compression ratio have on a standard engine ? Thanks again for your help. |
| RE: Head bolts Outer as in outside the rocker covers, or outer as in the 4 furthest away from the centre of the engine on a logitudinal line, same 4 bolts. You will notice on a head gasket that the bolts that tighten up to 70ftlbs or 180deg whichever you use, are spaced in a square pattern around the cylinder bore. NOT the 4 for and aft of the engine, these are needed to torque down the head gasket. Lowering the compression ratio will reduce the engine efficiency,(less power); on an older design using traditional controls, ie carb and dissy, as a rule of thumb, you should go no higher than 10:1. Aim for at least 9:1. My Rover engine will be 11:1 on EMS and EFI and I know of engines running higher than that. regards Kev |
| V8 Head Bolts | oldcobber | Engine Tech Tips & Questions | 10 | 15-01-07 10:24 AM |
| Head, Con Rod & Mains bolts | dbm10uk | Engine Tech Tips & Questions | 4 | 27-08-06 07:11 PM |
| Alan head bolts | JonnyT | General Tech Tips & Questions | 8 | 23-11-05 06:53 PM |
| Head Stretch Bolts | roger | General Tech Tips & Questions | 4 | 05-11-04 09:57 PM |
| What sealant to use on head bolts? | STEVE W | General Tech Tips & Questions | 5 | 20-06-03 05:59 PM |
