Results 1 to 6 of 6
Thread: Wildcat Heads
  1. #1
    Rik Hofste is offline Tyre Kicker
    Join Date
    Jan 2003
    Location
    Posts
    34
    Wildcat Heads
    The waiting was worthwhile, just received my Stage 1 Wildcat heads from Ian Ridchardson. My patience was stretched to the limit, while just before delivery he wanted them tested on a flowbench. Results were absolutely incredible !!!
    RPI claims on stage 3 heads (are these the ultra big valve heads ?)intake 97 CFM and exhaust 78.5 CFM.
    Wildcat stage 1.... 141,7 CFM on intake and 110,9 CFM on exhaust :wewar :wewar
    The full race heads will probably flow around 160 CFM on the intake !
    Now I am happy...
    Rik :tu
  2. #2
    FIA Jack Guest
    RE: Wildcat Heads
    Great result.
    Impertinent I know because you don't know me from Adam - but how much did they cost? I may need to factor them into next years budget and need to know how much to hide from the missus.
    cheers,
    Jack
    ps If you don't want to say, no probs.
  3. #3
    kev
    kev is offline Mechanic
    Join Date
    Feb 2007
    Location
    Stoke on Trent.
    Posts
    387
    RE: Wildcat Heads
    you need to budget around 2k depending on what you have done, Oh and by the way mine took 6 months from order to delivery ;(
  4. #4
    FIA Jack Guest
    RE: Wildcat Heads
    Kev,
    thanks for the info. I'd better start saving.
    Worth the wait I'm sure - they look the business.
    cheers
    Jack:tu
  5. #5
    chesterak is offline Chief Engineer
    Join Date
    Mar 2002
    Location
    Chester
    Posts
    1,533
    RE: Wildcat Heads
    I'm building a 5.0L Wildcat but without those beutifullllll heads - I can't afford them. Depending on what you are after, 115-120 CFM from good old Rover heads is quite easily attainable - my lad and his cousin with a flow bench have managed it.
    Stan
    :tu :tu
    Stan
  6. #6
    Join Date
    Jan 2003
    Location
    Posts
    34
    RE: Wildcat Heads
    The Wildcat heads start at GBP 1.850 for stage 1 and upto GBP 2.500 for the full race stage 2. You can also buy the castings and do the porting yourself.
    Regarding the flow figures.... John Eales prepared some full race heads for the comparation test in 1996 and these heads flowed 102,39 CFM on the intake against the Wildcat heads 128 CFM.
    According the guy at the Superflow bench, the best full race Rover heads he ever saw was with rewelded and raised inlet ports which flowed 107 CFM on the intake.
    www.espritv8.net/id294.htm
    www.espritv8.net/id292.htm
    www.espritv8.net/id293.htm
    Anyway, Ian Ridchardson knows his stuff and the flow on stage 1 heads is improved since then. :9 :9
    Rik
  1. WIldcat heads
    By kev in forum General Tech Tips & Questions
    Last Post: 24-09-06, 07:31 PM
  2. AFR heads greatly out perform other manufactors heads hand d
    By fastco in forum General Cobra Discussion
    Last Post: 04-09-06, 09:48 PM
  3. AFR 100% CNC ported heads VS Pro-Comps 100% CNC ported heads
    Last Post: 16-08-06, 06:12 PM
  4. new heads but it run like a dog
    By perky in forum Engine Tech Tips & Questions
    Last Post: 13-01-04, 09:29 PM
  5. Heads
    By 427sc in forum General Tech Tips & Questions
    Last Post: 15-12-02, 09:28 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
