| G-rotor pump After installing a fresh obtained intermediate timing cover with G-rotor pump on my block, I tested the lot before installing again in the car. Smart move, while I didn't get any pressure from the oil pump although the crank (and so the pump...) is turning smoothly :} :} I pushed vaseline in the gearwheel and filled the oil filter before installing but nothing happend. When I removed the oilpressure sender which is located just before there where the oil enters in the block you can feel that it sucks. It supposed to pump oil there.... (the crank is turning clockwise) Anybody any idea what I am doing wrong here ? Thanks, Rik |
| RE: G-rotor pump Nobody any advise ? |
| RE: G-rotor pump The obvious thing to check is the oil pressure relief valve isn't stuck in the open position. http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: G-rotor pump Thanks Kev, There are two oil pressure relief valves, haven't figured out what the second one is doing and why. Cheers, Rik |
| RV8 rotor arm | Sidecarbod | General Tech Tips & Questions | 3 | 03-06-06 11:49 PM |
| G-Rotor oil pump pressure | chesterak | Engine Tech Tips & Questions | 4 | 27-04-04 10:48 PM |
| G-Rotor pump priming | chesterak | Engine Tech Tips & Questions | 3 | 12-04-04 09:52 AM |
| RV8 G-Rotor oil pump | chesterak | Engine Tech Tips & Questions | 5 | 23-10-03 01:49 PM |
| G-rotor oil pump | Rik Hofste | Engine Tech Tips & Questions | 2 | 07-03-03 03:24 PM |
