Old 28-08-04, 06:02 PM
1" carb spacer for Weber
To aid hot starting issues I purchased a 1" carb spacer from Real Steel for my Weber 500/Edelbrock manifold (for an AK kit).
Problems are :
1. The studs are hardly long enough to fit the nut onto the end ! Real Steel claim that they are the longest ones that they do !
2. As per the photo, I need to mount my throttle cable bracket on the end of the stud !! As the studs are hardly long enough to fit a nut on, I am buggered !
3. With the long cobra aircleaner on top, the bonnet closes (just) but the aircleaner is pressed right up against it (I trust this is not good !).
Suggestions ? I am sure I have read of other people who have done this with a Rover/AK...
Thanks
Marcus
Old 28-08-04, 07:54 PM
Club Sec/Rep Liason
Re: 1" carb spacer for Weber
Hi Marcus.
1 + 2 are easily sorted by making longer studs from either studding or cut down set screws of the appropriate thead :thumb: The air cleaner issue could be remedied by lowering the bottom plate on the carb! I believe the recognised method is to stand on the top of the filter, and jump up and down a bit
AK 427 351C T5wc
Old 28-08-04, 09:05 PM
the air cleaner riser you have may be available in a smaller size to drop your cleaner height
ditto to the bolt issue,a local fastener specialist will sort you out there
gd jag,ford 302,tremec tr3550
Old 28-08-04, 09:13 PM
or if your confident enough,cut down the riser and square it off with a bit of filing and patience
Carb Spacer Question Speedy Gonzales General Tech Tips & Questions 10 13-06-06 11:09 PM
carb spacer Splitpin General Tech Tips & Questions 2 26-10-04 08:46 PM
Carb Spacer - which one ? Jake General Tech Tips & Questions 3 19-05-04 03:48 PM
Phenolic Carb. Spacer roger General Cobra Discussion 1 06-04-04 07:19 PM
Weber carb/Edelbrock fanimold chesterak Engine Tech Tips & Questions 10 07-03-03 03:25 PM
