| Re: Breather Jeff I've got mine set up like that: oil filler on one rocker cover and breather on the other. looks neat and works a treat. David |
| Re: Breather If there is no way air can get into the crankcase except by blowing past the piston rings you risk sucking oil out the sump, through the carb and burning it with the inlet charge. If is doesn't then you can thank a leaky rocker gasket or similar. Think about it, the object is to equalise crankcase pressure and air pressure not to suck your cheeks in until you are sick! |
| Re: Breather Hi, You must have an air inlet for the breathing system to work properly. The rocker covers you are using should have an inlet pipe on the rear of the LHS one or if the engine is an early type it will have the inlet down near the bellhousing on the RHS. These pipes should have a filter fitted to keep the dust out of your crankcase. Hope this helps Jim
__________________ www.jrv8.co.uk |
| Re: Breather thanks Guys just been and checked definatley no inlet on either rocker cover, these were originaly from a injection range rover. So looks like I need to drill a hole any, idea on what size it should be jeff
__________________ Jeff My next one WAS going to be AK but beginning to think I am to old to build anymore cars |
| Re: Breather Quote:
If the rocker covers are from an EFI RR I would expect to see the PCV at the rear of the NS cover. Mac |
| Re: Breather Mmmm It was a range rover injection as I removed the injection system to swap for a gear box. I guess some one may have changed them over before I layed my hands on the engine. So lads what size hole do I need to drill jeff
| Re: Breather Dont drill a hole. I Should have said that my pipe goes to a pankake air filter which gives the two way option you need . Can you route your pipe to an air filter? David |
| Re: Breather Hi , Take off the NS rocker cover and remove the splash plate from the inside (if fitted). At the rear of the cover on the inside you'll see a thick circular boss. Drill a hole through here and push a piece of pipe in from the top. Somewhere in the region of 7mm diameter will be fine and the pipe should be a tight fit in the hole. Replace the splash plate , cap the pipe with a miniature K + N filter and problem solved. Leave the "output" side of the breathing system as you have it, it's correct. Regards Jim
| Re: Breather Thanks Jim, One more job to do, just need my manifolds (on order with shinybitz) and I can start the beast jeff
| PCV breather connection | Downhill | General Tech Tips & Questions | 10 | 23-05-06 11:45 PM |
| Breather Hose | BlackRam | General Tech Tips & Questions | 3 | 06-10-04 10:31 AM |
| RV8 breather?? | Phil McCann | Engine Tech Tips & Questions | 2 | 14-05-04 09:43 AM |
| LT77 breather | tonym | Engine Tech Tips & Questions | 1 | 17-03-04 12:51 PM |
| Breather Advice? | cgnw28517 | General Cobra Discussion | 2 | 05-04-03 07:01 PM |
