| GD Steering arm bolts.... Gents, did anyone drill the new steering arm bolts for lock wire? Do you have to do this or can you get away with using threadlock? If you did drill them how did you do it? I can see its worth buying a jig just for four bolts! Also did you follow the video and stick the arms on after assembling the uprights to the chassis? I figured Id stick them on whilst Im building up the assembly on the bench? Any ideas?
| Yes you do need to use locking wire: the easiest way is to order new ones from Wards; not expensive & fast delivery. Paul |
| Thanks Gents, not sure if I made myself clear though. In the GD instructions it states that you replace the original Jag bolts with 2 from the bolt kit, it is these that must be drilled for lock wire. Having seen the posts about sub standard hardware before I decided that all my other bolts should be new and were ordered from Wards, hopefully they should be up to scratch. My question relates to the two new bolts from the GD bolt kit. PaulGD are you saying not to use the GD supplied ones and use Jag ones? (Ive already ordered Jag ones before I realised GD supplied their own) Cheers
| Andy To answer your original post, yes I drilled the bolts (I can`t exactly remember what size - probably 0.5mm bigger than the lockwire thickness). I just centre punched them and drilled them in a small drill press, holding them in the drill vice perfectly level and square to the drill. You have to drill quite gently as the hole is deep relative to the diameter, constantly lifting the drill back out of the hole to let the swarf out. Don`t forget to gently drill the ends of the holes with a larger drill to remove the sharp edges. I don`t know whether the SVA will accept thread lock or not?? Regards to whether to fit the arms first, or later - I honestly can`t remember????
| Help with Bolts for SD1 | martin_t | Engine Tech Tips & Questions | 16 | 12-07-06 12:34 AM |
| Con Rod Bolts RV8 | craizy | Engine Tech Tips & Questions | 2 | 03-07-05 06:53 PM |
| Bolts | Goldie | General Tech Tips & Questions | 9 | 31-08-04 11:21 PM |
| Steering Column Mounting Bolts | Trigger | General Tech Tips & Questions | 4 | 19-02-04 02:44 AM |
| Chevy 2 bolts VS 4 bolts | Jesus | General Tech Tips & Questions | 8 | 07-11-02 09:26 PM |
