Go Back   Cobra Club Forums > Tech Tips > Gardner Douglas Technical Questions
Home Forums Blogs Cobra Marques Info Groups Classifieds Gallery Arcade Shopping
Old 07-05-08, 08:35 PM
Simon R's Avatar
Simon R Simon R is offline
Fitting the body
I have tonight fitted the body..... or rather I have placed it upon the chassis and marvelled at how the body holes don't line up with mountings.
The body holes generally seem to need elongating upwards by up to 5mm - the worst one's being the front bulkhead ones - they all seem OK side to side..... does this match the experience of others? (Yes I have fitted the chassis sponge).
Also how the hell do you keep the body snug up against these front mountings whilst fettling the position? The slightest adjustment elsewhere sees gaps open easilly. I could fit the bolts in these but didn;t want to overstress the GRP when tweaking the position elsewhere.
And finally... how do I ensure that the body is square across the width of the chassis? Now I've covered the chassis up I've got no reference points?
Thanks in advance,
Simon
GDJAG0253
Chassis Now Rolling!
BAE 383 SBC in and running
MKIV Body Here
http://str-427-cobra.blogspot.com/
Old 07-05-08, 09:11 PM
RichardG's Avatar
RichardG RichardG is offline
I think the standard advise is to grease the mounts up with lard (or something else that will lube up the mounts but not rot the rubber). Also I think elongating the holes might not be a good idea, its bound to get the body in the wrong position that way. Have you got the body on four trolley jacks (one on each corner) so you can move the body around to line up on the mounts. Good luck.
Richard
GDtastic
Old 07-05-08, 09:16 PM
Simon R's Avatar
Greased them up with vaseline - went on no probs. I think I could move the body up to align the holes..... but then it won;t be sitting on the foam on the tunnel sheet.... is that a problem... if not then it begs the question as to it's purpose?
Simon
GDJAG0253
MKIV Body Here
Old 08-05-08, 06:56 AM
RichardG's Avatar
Simon
IIRC I fixed one bolt loosely (most likely the rear most one on the trans tunnel) and then got the one on the opposite side in next and worked my way forward along the body, jiggling the body up & down to align it as I went.
I guess the foam will have a fair amount of play in it so "resting on it" could actually mean lots of things from just about touching it to crushing it completely, so I guess its worth having.
Richard
GDtastic
Old 08-05-08, 12:44 PM
Simon R's Avatar
Thumbs down Bugger!
I found that by jacking and packing under the body floor I could get the mojority of holes cock on - particularly the ones on the front bulkhead.
However - disaster struck when the threaded insert on the offside front bulkhead mount became detached from the mount!!
Fortunately I found that by jacking thebody up 9 inches at the front and 12 at the back I could roll the chassis forward just far enough to undo the mount with a spanner and withdraw it. Close inspection showed it to be slightly deformed and the crimp wasn't formed correctly (rivnut type affair)
So currently sat waiting for a replacement mount from GD. 624 days to date so a couple more is neither here nor there I suppose.
Not a good day, but at least i didn't have to re-assemble the troops the lift the body off.
GDJAG0253
MKIV Body Here
Old 08-05-08, 04:58 PM
Andy302's Avatar
Andy302 Andy302 is offline
Top job Simon, looks like a real car now then?
Andy
Ford 302 331 BHP 324 ft/lb's , GD JAG249 rolling!!
www.andysgd427.blogspot.com
Old 08-05-08, 07:01 PM
RichardG's Avatar
Oh, I bet the air was blue!!
Glad it was going well (up until the mount came loose), and as you say don't worry about the odd setback I was seven odd years getting on the road and I'm still not finished
Richard
GDtastic
body fitting viperjim Viper Tech Forum 6 15-09-07 01:41 PM
Body Fitting pelham939 Pilgrim Sumo Technical Questions 3 01-05-06 06:50 PM
Fitting the Body SJ DAX Technical Questions 5 11-04-04 08:48 AM
Body Fitting ( GD Jag) MALC T General Tech Tips & Questions 5 13-03-04 07:50 PM
BODY FITTING keith w General Tech Tips & Questions 8 17-01-02 10:04 PM
