Go Back   Cobra Club Forums > Tech Tips > Gardner Douglas Technical Questions
Old 02-08-09, 11:32 PM
Cobra Rob's Avatar
GD Build
Not sure if this is the right section, but thought I would just throw up a post. I'm building my GD shortly and have got a right few bits but need loads
Anyone got bits they have not used or changed and don't require now.
Old 03-08-09, 05:50 AM
Simon R's Avatar
Club Member
Such as Rob? anything in particular?
Simon
I'm not a complete idiot...... some parts are missing......
Gone but not forgotten......GD-JAG BAE 383 SBC - See the build at Building a GD 427
Old 03-08-09, 11:50 AM
Cobra Rob's Avatar
There are loads of parts, I have been going through the GD Excel file and removing what I have already and leaving the parts I'm not sure about or that are required. It's a great job as it lets you price the car reasonably accurate, hmmmm maybe not the best thing then lol.
Anyways as far as i can see at the moment it will be most of the bits listed below, will be using a different steering wheel though I don't like the wooden ones I had one on my MGC roadster and just hated the feel of it. Must get some pickies up of the way it is now
Catches/Locks/Handles/Bolts Stainless Fuel Tank 12 gallon Fuel Sender Aston Alloy Fuel cap with integral locking cap 10mm Rubber Reinforced Fuel Hose (3 metres)Mk4 Aston fuel filler link pipe & silicone hose Standard High Volume Fuel FilterFuel-Safe Silicone Filler HosePedal Box, Brake Cylinder & Reservoir Rigid Pipe Set for Clutch & Brake MasterBraided Hose Bulklhead-Coupling (set of 3) Silicone Brake Fluid Hose - 2.5 metres 0.875 Clutch Cylinder & Reservoir Propshaft Speedo Cable Throttle Cable Throttle Cable Bracket Clova Twin Fan Kit + 275 BHP Chevy Silicone Coolant Hoses + Link HoseSVA Centre Balance Box 2.5" S/S Exhausts < 450 bhp Wiring/Body Loom, Relays & Fusebox Front and Rear Light Pack S.V.A. Side Repeaters (pair) S.V.A. Fog/Reverse Lights (pair) S.V.A. Reflectors (pair) Heater & Demister Kit Wiper Motor Drive & Wheel Box Wiper Arms & Blades/pair Washer Bottle KitInstrument Set Speedo(Elec),Ta,OP,WT,V,F Inst set as above but Smiths "Cobra" Classis styleElectronic Speed Transducer & Speedo Worm Drive Oil Temp Gauge & Sender Matching Time Clock S.V.A. Approved Rocker Switches Mk3 Lucas flick switch set - none SVAMk4 Classic Lucas flick swtch set + machined stalksHella Hazard SwitchWarning Lamp - set of 6 Standard GD Dash Loom Brake Light Switch Brake Light Switch bracket Air HornAir Horn S/S bracketBattery cable setBattery Tray Front number plate bar - stainlessClamp-On Rear View Mirror SVA Door Mirrors/pair S.V.A. Windscreen - Tint Windscreen Stay & Escutcheons SVA screen pillars lower cover plates SVA Mk4 under dash covers and vent plates Windwings with Hinges Sunvisors - Smoked/pair Front Nudge Bar S/Steel Rear Nudge Bar S/Steel Front Nudge Bar Mountings/pair Chrome Over-rider (each) Polished S/Steel Side Vents (Pre-Formed)/pair Carbon fibre Stone Guards/pair Fog & Reverse Light Stand-Offs/pairRear Over-rider Stand-Offs/pairSingle Width S/Steel Roll Loop 2 off Roll Bar Grommets x 6 Bonnet, Boot & Door Seals Premium Quality Carpet Set Mk4 Leather Bucket Seats/pr. - Mk4 high backLeather Door Panels, Dash & Gaiters SVA Approved GRP Dash Panel S/Steel Interior Escutcheons Mohair Hood & DIY Fixings with GRP surround Mohair Hood & DIY Fixings Stud FasteningMohair Tonneau Mohair Tonneau (Roll Bar) Side screen catches & Rubber sealsSide screen Hinges18" 3 Piece Wheels - GDEURO Mk4Wheel Spinners set of 4 Lock Plates set of 4Wheel Nuts set of 20 18" Toyo Proxes T1R Tyres - Mk4 Willans 4 Point Harness (each) MotoLita reproduction "cobra" wood steering wheelMotoLita polished alloy Steering Hub for Mk4MotoLita polished alloy centre horn push for Mk3MotoLita polished alloy centre cap for Mk4GD LS Air Intake Box & FilterBosch Fuel PumpHigh Volume EFI Fuel FilterBraided Fuel Hoses & FittingsLS Fuel Pressure RegulatorLS Fuel rail adapter to -6
Old 03-08-09, 02:03 PM
chiffer's Avatar
Hi Rob. Not a lot then . Anyway I have the perspex side screens inc. rubber seals and catches (rarely used). S/steel front nudge bar mountings with a pair of chrome over-riders (brand new). I also have one Willans club harness 4x4 (saloon) 2"/3" (LH) F.I.A. approved in black inc. fastenings (used once). PM me if your interested.
CHRIS
GD Mk3, Chevy 350, 420bhp.
Old 03-08-09, 04:26 PM
Cobra Rob's Avatar
Will do
Old 03-08-09, 05:00 PM
Miket's Avatar
Extremely Senior Member!!
Rob
There is a wanted section in the classifieds.
Mike
Cobraless
With Age Comes Skills, It's Called "Multi Tasking"
I Can
Laugh, Cough, Sneeze, Fart and Pee all at the same time.
Old 03-08-09, 06:09 PM
Cobra Rob's Avatar
Looked there a few times but nout really pops up, more fun in here
Old 03-08-09, 07:28 PM
Miket's Avatar
Put what you want in the "WANTED SECTION"
More chance of folks seeing it, instead of this thread getting buried with the rest.
Mike
Cobraless
I Can
Old 04-08-09, 08:29 AM
shadow's Avatar
Oh and make it a proper list, otherwise some may think its a post by Dr Dee.
Old 04-08-09, 10:55 AM
Cobra Rob's Avatar
Dr Dee lol I'm staying out of that one its as bad as Kenco
My list above was proper lol, just when it posted it squished them all together. Anyways I think I'm getting slow or sommit, buggered if I can find out how to submit a thread in the wanted section, so sticking with this for now as its working ok.
the Build
GD Mk4, LS6, T56 6 speed box, 400bhp +.
http://robscobra.blogspot.com/
If what I say can be taken in 2 ways and one of those gets you angry....I meant it the other way
BB code is On
AK or DAX to build. simar355 General Cobra Discussion 14 07-06-09 10:12 PM
How much to build a Dax? simon General Cobra Discussion 5 09-12-04 12:37 AM
And for my next build.... chesterak General Cobra Discussion 3 11-10-04 10:32 PM
new build eams General Cobra Discussion 12 05-02-04 06:02 PM
Dax build David General Cobra Discussion 0 16-09-01 10:32 PM
