Go Back   Cobra Club Forums > Tech Tips > Gardner Douglas Technical Questions
Old 23-04-10, 06:54 AM
martin_t's Avatar
Number plate light
Hi
When fitting the number plate light to the GD, I understand that the wire has to go through the strengthening ribs in the boot lid. What I am not sure of is how it gets there. Am I right in assuming it passed through the nearside hinge? If thats the case do I drill a hole near the bend of the hinge for the entry point or is there some other method?
Martin
GD427 Mk4 - Chassis rolling.
MK4 Body (in black!!) fitted.
On course for IVA, late summer 2010!
GD Chassis J0258.
www.martins-cobra.co.uk
Old 23-04-10, 07:10 AM
shadow's Avatar
I managed to go direct through the boot skin, Hole to hole. I cut part of the loom off in the boot to give a join and plenty to play with free away from the boot. Fed the loom through the hinge as much as needed, then soldered a single wire to the loom, taped and greased the sheathing and eventually fed the single wire to the other hole and slowly pulled. Pics in my blog.
Not quite sure about the ribs, as they are at the sided and the holes are in the middle.
Good luck, not a quick job.
Steve.
So close. It's a bit like touching cloth.
http://www.cobnut.blogspot.com
Old 23-04-10, 09:01 AM
JimmyJazz's Avatar
Hi Martin
Yes it goes through the n/s hinge, you need to drill two holes as picture.
I stripped a single wire from a bit 2.5mm twin and earth and used that to fish through the route, then hooked and taped the tail light wire on it and pulled them through. be careful not to pull to hard as it will get trapped inbetween the two skins. It's quite straight forward if you do it in sections from access hole to hole.
............. Alan
________________________________________
BUILDING ALL DONE
IVA PASSED
ROLL ON THE SUMMER
http://gd427cobrabuild.blogspot.com/
Old 23-04-10, 09:42 AM
shadow's Avatar
Oh, I see, that way....... ooops
Steve.
Old 23-04-10, 05:43 PM
Club Sec/Rep Liason
Please don't take this as a criticism or a pop at GD (well just a small one then ) But wouldn't it be far simpler if they ran a pair of wires inside the boot lid when they bond the two halves together? It works for other manufacturers.
AK 427 351C T5wc
Old 23-04-10, 07:37 PM
JimmyJazz's Avatar
It's funny you should mention that, I made just that comment at GD when I was in there last week. Suffice to say they've thought about it but never got round to it.
............. Alan
BUILDING ALL DONE
IVA PASSED
ROLL ON THE SUMMER
Old 23-04-10, 08:25 PM
martin_t's Avatar
Number plate light
Very good idea!!
Martin
GD Chassis J0258.
Old 23-04-10, 09:27 PM
i used a tig rod to go directly from hole to hole, then pulled a wire through. took 5 mins
Steve
DAX 383 ci SBC 440hp...SOLD
GD Euro mk4, 427 C.I. LS7, 540 hp...SOLD
Project Tango "Old School" GD in progress
BB code is On
Got the Number Plate for the AK & its..... Martyn-ak427 General Cobra Discussion 0 16-10-09 08:15 AM
Number Plate Light Again - last time promise pelham939 Pilgrim Sumo Technical Questions 2 21-03-07 11:01 AM
Number plate light BenBaron General Tech Tips & Questions 2 14-12-06 03:42 PM
Number Plate Light Phil McCann Pilgrim Sumo Technical Questions 17 20-03-05 06:18 PM
Wiring the number plate light Robin427 General Tech Tips & Questions 10 13-05-04 07:08 PM
