| ROVER OIL PUMP PRIMING TOOL IVE TRIED REAL STEEL AND RIMMER BROS,NON IN STOCK FOR AT LEAST A MONTH,HAS ANYONE GOT ONE I COULD BORROW/PURCHASE,HELP,THANKS IN ANTICIPATION |
| RE: ROVER OIL PUMP PRIMING TOOL I made my own from a piece of round CRS turned one end down to 12mm about 50mm long so that it will fit in your drill and the other end to fit the oil pump drive collar on your Distributor. |Knock the pin out that holds it to the disributor and then drill and pin it to your home made shaft. It works a treat. Otherwise where do you live and we will see if a loan can be arranged.But you will still have to use the drive collar off of the bottom of your own distributor. |
| RE: ROVER OIL PUMP PRIMING TOOL THANKYOU ALL,I NOW HAVE ONE.AND IT DID THE JOB JUST DANDY |
| RE: ROVER OIL PUMP PRIMING TOOL you don't need a tool just pack with vasaline or petroleum jelly |
| Priming oil on 4.6 Rover V8 | craggle | Engine Tech Tips & Questions | 6 | 17-08-07 06:44 PM |
| oil pump priming | qkingston | Engine Tech Tips & Questions | 2 | 03-03-07 09:11 AM |
| Oil pump priming | Serge | Engine Tech Tips & Questions | 6 | 27-11-04 05:12 PM |
| Oil pump priming | David Horsnell | Engine Tech Tips & Questions | 10 | 26-11-04 08:19 PM |
| G-Rotor pump priming | chesterak | Engine Tech Tips & Questions | 3 | 12-04-04 08:52 AM |
