| Re: Xmas come early I believe Robin has installed the same unit into his GD. He has a website as well ! Ian
__________________ Ian British American Engines / Daytonas www.britishamericanengines.co.uk / www.badaytona.com You Tube Channel: http://youtube.com/profile?user=BigThirsty1 Latest Build: Brian Cartmels 330 bhp turn key Chevy 350 C.I. for his Cobra replica http://uk.youtube.com/watch?v=AopjO3wu5rI |
| Re: Xmas come early Quote:
Thanks Chris Thats one I over looked Cheer's Dave
__________________ GD427 MK4 LS6 |
| Re: Xmas come early My website has some info about the electrics. The thermostat housing I had cut and welded by GD to fit it - might be cheaper than buying a straight one. I didn't find the electrics too bad - there are a lot of wires but you can trace most of them and remove quite a few. I've driven about 200 miles in my car so far and had no problems with the engine (apart from the HT lead that keeps coming loose!!). I know some others have had a problem. If you haven't had VATS programmed out of the PCM, I would recommend buying a VATS/O2 module from Baker Electronics. This costs about £20 and will not only fool the car into thinking that you have VATS but also give a rear O2 simulated signal to the PCM that fools it that the Cats are doing something Feel free to e-mail me on robin(at)creffield.com
| Re: Xmas come early Ooh, just thought. Make sure you have the clutch hose fitting as it is a bespoke part and difficult to source. Get as much of the wiring as you possibly can
| Re: Xmas come early Dave Spare set of plugs , oil filters, O2 sensors all cheaper over there. I converted to an electronic oil pressure sender and made up my own manifold block for oil pressure & temperature. S & P do a `tree` to do the same thing, just a thought at this stage. Water header tank cap - again S & P do some nice ones with polished tops. Mine came without the plug connector for reverse and took ages to track down. Try JP exhaust for your cats , they can flange them to suit and did a great job. Is your harness being modified for `stand alone` ? Trevor
__________________ GDO5COB LS1 / T56 |
| Re: Xmas come early Look forward to hearing about you experiences with the de-rated diff. Mine was not de-rated and it is certainly very noticeable at low speeds.
Thanks Robin May possibly be in touch when I get to the wiring stage, I've seen the info on you web site this will certainly help Thanks. I'm sure the VATS will be programmed out of my PCM but thanks for the advise on this - I'm not sure at the moment what I'm going to do regarding Cats - I'm quite set on side pipes with the 4 into 1 arrangement but not sure how this will work - Any body got any idea's or advise? may just have to settle for under-slug to get through SVA and may be change at a later stage. On the clutch hose thanks for pointing this out I haven't seen that type of fitting before - I sent a email to the guy who supplied the package, he's replied asking me if I also need the Master cylinder - will the one GD supply be OK or should I have him send the hose and cylinder over? Thanks for your help Dave.
| early SRV8 | denis84 | General Cobra Discussion | 45 | 05-09-06 08:34 AM |
| Early Xmas Pressie Wot You Think? | rangrov | General Cobra Discussion | 10 | 01-12-05 03:06 PM |
| early dax hardtop | neil still building it | DAX Technical Questions | 2 | 24-09-05 07:37 AM |
| An early result, now in!! | Grease Monkey | General Cobra Discussion | 15 | 07-05-05 05:21 PM |
| Early Dax | roll control | General Cobra Discussion | 5 | 15-12-02 01:22 PM |
