  #11 (permalink)
Old 13-02-06, 09:25 PM
gareth08's Avatar
Re: MSD coil
If you're using the MSD ignition with an MSD dizzy and the blaster coil only then the coil is fed directly from the Ignition Modul.Orange is + and Black is -.
Is your coil earthed ok.
What Plug leads you using!!!!
You CAN'T use solid core leads with an MSD.
Gareth
  #12 (permalink)
Old 13-02-06, 09:36 PM
Clarkson's Avatar
Speed junkie
Re: MSD coil
Yeah as you say,the coil is only wired by 2 wires from the MSD control box.
Yes I do have solid core cables,but that only affects the rev limiter. So i'm told.
David
2nd baby due 23rd Jan.
  #13 (permalink)
Old 13-02-06, 09:44 PM
gareth08's Avatar
Re: MSD coil
Noooooooooooooo!!!!!!!!!!!!
Theres you're problem.
Solid core lead's.
From MSD tech info (Solid core spark plug wires CANNOT be used with an MSD ignition)
They cause a higher voltage build up in the inductive side of the ignition which in turn will increase the output to the coil via the capacitive discharge.
New leads , new coil , check it is eathed ok and away you go
Gareth
  #14 (permalink)
Old 13-02-06, 09:53 PM
Clarkson's Avatar
Speed junkie
Re: MSD coil
Solid core lead's.
Do you think so??? Sounds right/makes sense! Where did you read that from??
What leads do I need?? Msd??
David
  #15 (permalink)
Old 13-02-06, 09:59 PM
Miket's Avatar
Fully Paid Up Grandad
Re: MSD coil
I've got 8mm Moroso Blue Max Spiral Core with my MSD 6AL.
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
  #16 (permalink)
Old 13-02-06, 10:05 PM
Clarkson's Avatar
Speed junkie
Re: MSD coil
Thanks Gareth & mike!
David
  #17 (permalink)
Old 13-02-06, 10:10 PM
Clarkson's Avatar
Speed junkie
Re: MSD coil
Tim, What ignition was you using on the dyno??
David
  #18 (permalink)
Old 13-02-06, 10:15 PM
gareth08's Avatar
Re: MSD coil
Yes
Yes
MSD tech info + I was an electrical/mechanical enginneer which helps
MSD Heli-core or any helically or spiral wound wire ones.
Summit do loads of different types just depends on how much you want to spend
Gareth
  #19 (permalink)
Old 13-02-06, 10:16 PM
gareth08's Avatar
Re: MSD coil
Tim,
Any news on the GT 40 heads
Gareth
  #20 (permalink)
Old 13-02-06, 10:19 PM
Clarkson's Avatar
Speed junkie
Re: MSD coil
Thanks Gareth, More bloody money! I wounder if it's damaged my 6AL??
David
12 V coil jeff General Tech Tips & Questions 5 16-03-06 08:06 PM
Coil over shocks mouldb General Cobra Discussion 0 27-02-05 11:35 PM
Coil over shockers mouldb Pilgrim Sumo Technical Questions 0 27-02-05 11:04 PM
RV8 Coil stu e Engine Tech Tips & Questions 0 01-02-05 06:34 PM
which coil ? beanpole Engine Tech Tips & Questions 5 30-07-04 11:39 AM
