Old 03-03-06, 10:01 PM
Rear lights
Having just insatlled my rear lights I am now toatally confused.
Is it purely personal or is there a reason, SVA?, why some cars have the indicators above the stop lights and vice versa?
Russ
Old 04-03-06, 02:31 AM
Re: Rear lights
Indicators need to be a certain height above the ground... think brake lights do too... you will probably find that the indicators are high enough in the lower position - I think it is safer having brake lights higher...
Reverend Robin
GD427 Euro
World Rivnut Champion 2007
Old 04-03-06, 02:45 PM
Clive's Avatar
Re: Rear lights
Hi Russ the regs for the rear lights are as follows.
Rear position lights. Within 400mm of edge of vehicle. Min seperation 500mm. Max height 1500mm. Min height 350mm. Visibility 80 degrees outward, 45 degrees inward. 15 degrees above & below the horizontal or 15 degrees above & 5 degrees below if less than 750mm above ground level.
Stop Lamps Minimum seperation 400mm. Max/min heights as rear position lights. Visibility 45 degrees inward & outward. 15 degrees above & below horizontal or 15 above & 5 below if less than 750mm above ground.
Rear Indicators Height & position as rear position lights. Visability as rear position lights with 50% of illuminated area to be visible throughout tis arc. Fashing rate of 60 to 100 per minute.
Hope this helps
Clive.
PS whereabouts in Edinburgh are you?
Cheers, Clive
Old 04-03-06, 08:31 PM
Re: Rear lights
The AC 289 (post 427 model developed for the European market) and late 427 with separate rear/stop lights and idicators had their indicators above the rear/stop lights.
When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there\'s no end to what you can\'t do!
Old 04-03-06, 09:07 PM
Re: Rear lights
Clive,
Thanks,
They are wired now and not moving, stop/tail at the top.
Nice to hear that there is somebody else up here.
What car do you have?
I am just oustside Balerno on the hill , 100yds of the B7030 that runs between the A70 and A71.
If you know where the gliding place is, Kirknewton air strip, I am next to that.
Where in Perth are you?
Russ
Old 05-03-06, 12:33 AM
Clive's Avatar
Re: Rear lights
Originally Posted by russj
Clive,
Thanks,
Russ
Hi Russ, I've sent you a PM
Clive.
Cheers, Clive
Rear Lights NASSTY General Cobra Discussion 18 04-01-06 11:46 AM
Rear Lights Phil McCann Pilgrim Sumo Technical Questions 6 13-11-04 05:16 PM
Rear Lights Bigblock General Tech Tips & Questions 2 15-09-03 09:31 PM
Rear Fog Lights SimonP General Tech Tips & Questions 17 20-03-03 04:30 PM
Rear lights Shelby General Cobra Discussion 1 28-02-02 06:50 PM
