| Getrag Gearbox Chaps, I am just starting to clean up the exterior surface of my getrag & am wondering what is the best way to finish it, ie polish the aluminium & give it a coat of lacquer or clean it up & paint with swift coat of silver hammerite? Any info appreciated. Regards, Martyn
__________________ AK with tyre-lighting 393ci Ford Stroker - 480hp & 475ft/lbs! - (build about 90% complete..) "Girdles Are For Fat Chicks Not Engines" |
| Re: Getrag Gearbox Hi Martyn , I de-greased mine then sprayed it with silver zinc spray and then clear lacquer to seal the zinc surface . Looks like new ! |
| Re: Getrag Gearbox Not being a paint expert it's always a problem knowing what to do for the best on Aluminium. If its painted and it chips, moisture gets underneath and it festers and the paint flakes off leaving pits and the powdery white aluminium oxide. Look at Alloy wheels that have not been cared for, after a few years. The Gearbox is pretty well out of reach so is unlikely to be well cared for. In any case Aluminium whether castings or otherwise really needs fully degreasing and a proper etch primer before any paint. It is also wise to ensure that the entire paint system is compatible if the job is to last any length of time. Of course it depends whether you want it to look good for six months or 6 years. I know some spray paints claim to be suitable for use on all metals but over the years I have found them not to be so long term. If it were me I would probably get it fully degreased, etch primed and then painted whether by brush or spray. Just my 2 penneth.... Denis
__________________ If you take something to bits often enough, eventually you'll have two of them...... GD427E039 |
| Re: Getrag Gearbox Polished ally bellhousing and zinc spray paint on gearbox, still looks as good as new after 10.000 miles.
| Re: Getrag Gearbox I fear you might have too much time on your hands! Surely you can hardly see it when installed. I just cleaned mine up with parafin, worked in with a brush. Any sort of coating might break down after a while.
__________________ Robin AK427 sporadically in a state of build. |
| Re: Getrag Gearbox Quote:
I certainly took quite a bit of care getting the supension bits all nicely covered in POR 15. Each to their own!
| Getrag gearbox | chesterak | General Tech Tips & Questions | 17 | 23-04-07 03:47 PM |
| Getrag Gearbox | TINKA | General Tech Tips & Questions | 13 | 08-06-06 07:26 PM |
| Getrag gearbox | ryan | General Cobra Discussion | 2 | 11-08-05 11:04 PM |
| What to look for with a Getrag gearbox | garyholden | General Cobra Discussion | 14 | 24-09-04 06:03 PM |
| Getrag gearbox | richardd | General Tech Tips & Questions | 7 | 03-06-04 08:25 PM |
