Old 14-03-06, 05:00 PM
Daxman's Avatar
fuel filter position
Hi Guy's
Just a quick question, can some tell me if i should position a fuel filter before the mech pump to protect it, or is it okay to have an inline filter between the pump and carb.
Many thanks
Russ
DAX DE DION - HUDDART 383
Old 14-03-06, 05:12 PM
Clive's Avatar
Re: fuel filter position
Originally Posted by Daxman
Hi Guy's
Many thanks
Russ
Hi Russ, I would put the filter between the tank & the pump, this will filter out anything before it gets to the pump. If you like you could also put one after the pump too.
Clive.
Cheers, Clive
chedz's Avatar
I've put one each side of the pump, both in the boot area. The little clear plastic ones. I decided not to put the one after the pump in the engine bay as its just another opportunity for a leak and a fire in the engine bay.
Chedz
Old 14-03-06, 05:33 PM
Neil O's Avatar
What engine are you running?
If you're using a reasonably high performance engine, you'll need the larger plastic filters at least.
Crendon, Ford Sideoiler 427
Old 14-03-06, 05:53 PM
Daxman's Avatar
i'm going to be running a sbc 383 with around 500bhp, i was looking at using one of those filter king filters for V8's, and intend on mounting it in the engine bay some where.
Russ
Old 14-03-06, 06:01 PM
I thought most filter kings have a pressure regulator in them so it would be pointless fitting it before the pump if this is the case with yours, I have fitted a filter before and after the pump just to be safe.
Old 14-03-06, 06:03 PM
Hi,
We found that there is a handy space next to the diff, just in front and below the drive shaft - that is where we put our filter. Speedflow ( www.speedflow.co.uk ) do a couple of good filters for larger V8's....
This allowed it to be before the pump, out of harms way (the larger filters take up a lot of room in the engine bay). The pump we put next to the prop shaft, as is traditional on Dax's...
Simon
www.sounds-legal.com
Fuel Filter Position Martyn-ak427 AK Technical Questions 0 24-09-06 10:52 PM
Fuel Pump Position Steve Faithful Ram Forum 11 21-01-06 05:55 PM
Fuel filter graham General Tech Tips & Questions 12 24-11-03 01:17 PM
Fuel Pump Position mjculley General Tech Tips & Questions 1 06-10-03 07:33 PM
Fuel filler, position on rear wing simon General Cobra Discussion 11 07-11-02 09:12 PM
